Need help asap this morning!!!
Old Mar 15, 2008 | 06:40 AM
totsie7944's Avatar
Default Need help asap this morning!!!
Hey so I grabbed the axles under my gf's car once I got it jacked up and the passenger side axle (mitsubishi galants are reversed, tranny on drivers side) and the axles was making a clicking noise and NOT tight in the tranny....so is this a tell tail sign that THAT axle is the one causing the shaking in higher gears ONLY upon acceleration?
Does this sound like a new axle should fix the problem?
Also, I am a bit confused on how to get the ball joint out of the control arm? Unlike our ITR's, which have the nut at the bottom to remove, hers is a flat piece of metal? Does anyone know what I'm talking about and have a quick advice on how to get her knuckle free?
Thanks guys! I gotta get this done today!
Old Mar 15, 2008 | 09:19 AM
Yah Its a R's Avatar
Default Re: Need help asap this morning!!! (totsie7944)
Hey totsie, If it's flopping around in the trans or at the joints, then yea. Even if its not that noise, thats not safe lol.And the nut might be under the axle boot or you might have to pull the knuckle down off the strut like on a taurus??? Just a suggestion, cars suck..Good Luck
mandalorianjedi
Apr 10, 2009 06:05 AM
i slam guys
29
Aug 19, 2006 02:25 AM
iBear
16
Oct 24, 2004 08:37 PM
95GSRTT
Aug 4, 2004 10:01 PM
turbod16y7vtec
Aug 4, 2002 09:51 AM
