Buying H2B need help on parts list...
Very new to hondas so i have some questions. Does it matter if the h22 was automatic and if so how can i tell the difference? Any things to look out for when buying a h22? Also which tranny should i be after? Do any besides the typr r come with lsd? Any tips will be appreciated
buy my entire setup
https://honda-tech.com/zerothread?id=2211581
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboedsupe »</TD></TR><TR><TD CLASS="quote">Help a newbie out guys. Which tranny should i buy and does the motor matter if it was from a automatic?</TD></TR></TABLE>
The tranny decision is more of a preference based on your goals and or use of the vehicle.. Anything from a GSR to a JDM ITR is typically used.
The H22 can be an auto, there is no difference between the auto and manual blocks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboedsupe »</TD></TR><TR><TD CLASS="quote">Very new to hondas so i have some questions. Does it matter if the h22 was automatic and if so how can i tell the difference? Any things to look out for when buying a h22? Also which tranny should i be after? Do any besides the typr r come with lsd? Any tips will be appreciated</TD></TR></TABLE>
if the H22 that you buy is an Auto you will have to buy a flywheel for it (which you have to get a B series one anyway) . thats about the only difference. the flywheel will bolt on in place of the auto plate.
