d15b7 into a 91 si hatchback
Old Mar 14, 2008 | 06:08 PM
REV CRX's Avatar
Default d15b7 into a 91 si hatchback
I got a d15b7 that i bought for $200 and i was looking into buying a 91 civic si hatchback and i was wondering what would i need to make this possible
Old Mar 14, 2008 | 06:40 PM
Serdar's Avatar
Default Re: d15b7 into a 91 si hatchback (REV CRX)
if the Si motor was bad then all you would have to do is replace the old short block with the d15b7 short block. use all the old intake manifold setup, exhaust manifold, distributor etc. on the d15b7 and your set.
Old Mar 14, 2008 | 06:46 PM
REV CRX's Avatar
the si is only a shell
Old Mar 15, 2008 | 03:19 PM
KsiB's Avatar
Multi port fuel injection manifold, engine wire harness, ecu, and dist.
adamyee
25
May 23, 2010 12:47 PM
EnjoySi
Appearance Build Threads
22
Sep 12, 2009 06:04 PM
Timmah!!
Jul 16, 2001 06:54 PM
