b16 questions
The swap doesn't matter...
What motor mounts do you have? Thats where the vibration is coming from... Some motor mount bushings are stiffer than others.
i have all hasport mounts... a friend told me if i cut off the transmission mount on the front cross member it will stop the vibrating??? idk how true that is.
Don't cut it off, unbolt it and see if it makes a difference. I don't have a 4th mount on the crossmember, and it doesn't rattle...
( I have no name mounts with semi-soft bushings.)
i have hasport mounts in my b16 crx also with no 4th mount. car still rattles anyway. there is not much you can do to cut down the vibration with those mounts.
painterbob
Sep 26, 2008 01:52 PM
