no speedo since trans swap??????
Old Mar 14, 2008 | 01:37 PM
jr000's Avatar
Default no speedo since trans swap??????
okay i have a 96 civic ex...sohc vtec....d16y8 with stock trans....i swaped the trans with a 92-95 dx trans and my speedo is not working now....i am selling my car tomorrow so i need to fix it tonight...any help would be great...thanks guys
also are the vss's(vehicle speed sensors) the same on both trannys or are they different...i have both vss's but i tried both and neither worked...should i clean the contacts on the harness's? thanks again guys
Modified by jr000 at 2:53 PM 3/14/2008
Old Mar 14, 2008 | 02:56 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: no speedo since trans swap?????? (jr000)
make sure you have the speedo ring gear on the diff of the transmission, without, it wont work
Old May 8, 2008 | 11:08 AM
JJ's civic's Avatar
Default Re: no speedo since trans swap?????? (n1_egsex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex &raquo;</TD></TR><TR><TD CLASS="quote">make sure you have the speedo ring gear on the diff of the transmission, without, it wont work</TD></TR></TABLE>
what is this? i'm having the same prob.
Old May 8, 2008 | 11:27 AM
hardcore97's Avatar
Default Re: no speedo since trans swap?????? (JJ's civic)
did you use the same vss or the one that was on the vss tranny? try using the one off the y8
Old May 8, 2008 | 11:30 AM
Phoenix_ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJ’s civic &raquo;</TD></TR><TR><TD CLASS="quote">
what is this? i'm having the same prob.</TD></TR></TABLE>
the speedo ring gear is the gear that turns the VSS. if you pull out your VSS, you'll see that it's gear driven similar to the distributer setup on an old V8. if you're missing the ring gear, there's nothing to turn the VSS and therefore no speedo.
in all honestly, i doubt that would be the problem -- unless somebody pulled the gearbox apart and reassembled it incorrectly. it's more likely a bad VSS or a wiring issue.
Old May 8, 2008 | 12:42 PM
JJ's civic's Avatar
Default Re: no speedo since trans swap?????? (Phoenix_ITR)
well all i ddid was unplugh it. but when i pull the codes i got vss. no i replaced the vss with a known working one from my old tranny and still haveing same prob
Old May 8, 2008 | 01:19 PM
Jimmy's Avatar
Global Moderator
Pull the harness plug from the vehicle speed sensor.. There are 3 prongs.. make sure they are all still in tact and not broken off inside the plug.
This is a common problem.
Old May 9, 2008 | 02:49 PM
JJ's civic's Avatar
Default Re: (Jimmy)
i got it to work i had to change both piece of the vss the vss it self and the plug part.
Danielsb20crx
Honda CR-V & Element
Jan 29, 2013 04:46 PM
zdizzle
May 18, 2007 07:32 AM
DC4_MADMAN
Jul 23, 2006 02:56 PM
SiMateoAko
Dec 24, 2005 01:43 PM
