gsr gauge cluster
Old Mar 14, 2008 | 01:00 PM
dc2much's Avatar
Default gsr gauge cluster
ok i just installed a gsr gauge cluster and the gas and engine temp dont work. is there a way to fix that. or is there something i forgot to transfer from my ls cluster
Old Mar 14, 2008 | 01:13 PM
yc_dc4mar's Avatar
Default Re: gsr gauge cluster (dc2much)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2much &raquo;</TD></TR><TR><TD CLASS="quote">ok i just installed a gsr gauge cluster and the gas and engine temp dont work. is there a way to fix that. or is there something i forgot to transfer from my ls cluster</TD></TR></TABLE>
it doesnt matter if you switch the gauges from you ls one, it still wont work. switch the green layer on the back from you ls one to the gsr one then it will work. OR switch all the gsr gauges into your ls cluster and use the ls cluster
Old Mar 14, 2008 | 04:55 PM
BlueIntegraBoy's Avatar
Default Re: gsr gauge cluster (yc_dc4mar)
I don't recommend swapping films if your car is a 94-97 and cluster from 98-01, or vice versa. You'll lose your ABS light.
I highly recommend swapping all of the four gauges from the GSR cluster into the LS cluster housing.
Old Mar 14, 2008 | 05:13 PM
dc2much's Avatar
Default Re: gsr gauge cluster (BlueIntegraBoy)
ok i swapped all of my clusters from the gsr cluster to my ls. everything works that i know of except the fuel gauge. the needle moves but it goes all the way past the full line. when i took my other cluster out it said i had alittle more than 3/4 of a tank. and now it is past the full line. did i do anything wrong? any help or things that i can look for?
Old Mar 14, 2008 | 05:25 PM
Ok, you put the GSR internals into the LS housing? What yr is your car and what yr is the cluster from?
Old Mar 14, 2008 | 05:31 PM
dc2much's Avatar
my car is a 94 im not sure what year the other gauge cluster is. it does have a abs light on it. i want to say that the guy i bought it off said it was a 95 or 96 but i am not 100 percent. also the light on my speed( the one that shows how fast you are going) is dim. the miles are lite up fine.
Old Mar 14, 2008 | 05:34 PM
So, you have the 94 LS cluster with the 94 LS cluster's film on and the GSR gauges in the 94 LS cluster housing?
Old Mar 14, 2008 | 05:39 PM
dc2much's Avatar
ok i took the gauges from the gsr cluster. took off the gauges on my ls and put the gsr on. i replaced the engine temp, rpm, speedometer, and fuel gauge on the ls
Old Mar 14, 2008 | 05:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2much &raquo;</TD></TR><TR><TD CLASS="quote">ok i took the gauges from the gsr cluster. took off the gauges on my ls and put the gsr on. i replaced the engine temp, rpm, speedometer, and fuel gauge on the ls</TD></TR></TABLE>
Your fuel gauge should have worked unless it's a bad fuel gauge. Can't you reuse your LS fuel gauge since it should be the same colored faces (94-97 gray, 98-01 black)?
Old Mar 14, 2008 | 05:44 PM
dc2much's Avatar
yea. um do you know why the speedometer isnt as bright as the rest of the gauges
Old Mar 14, 2008 | 08:04 PM
Burnt bulb perhaps
Old Mar 15, 2008 | 10:25 AM
dc2much's Avatar
ok i swaped the fuel gauge out and it is doing the same thing. it will move but it moves all the way full
Old Mar 15, 2008 | 11:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2much &raquo;</TD></TR><TR><TD CLASS="quote">ok i swaped the fuel gauge out and it is doing the same thing. it will move but it moves all the way full</TD></TR></TABLE>
You sure you didn't swap the films?
Old Mar 15, 2008 | 02:11 PM
dc2much's Avatar
the film that is on the gauge cluster is the ls one
Old Mar 15, 2008 | 02:20 PM
Try one more thing. Swap everything back into the GSR cluster housing. If it's from a 95, it should work.
Old Mar 15, 2008 | 02:32 PM
dc2much's Avatar
use the gsr film
Old Mar 15, 2008 | 02:36 PM
yc_dc4mar's Avatar
it sounds like you mixed everything up
which ever cluster you had before...take out all the gauges. leave the film. the new cluster. take out all the gauges and put them in your old cluster. anything that doesnt work. switch back. that should fix your problem.
Old Mar 15, 2008 | 02:43 PM
dc2much's Avatar
ok but why does the coolent temp work and the fuel doesnt work right
Old Mar 15, 2008 | 02:46 PM
yc_dc4mar's Avatar
to be honest i dont know. it has something to do with the wiring in the car and the wiring in the cluster. they have to match. just do what i said up there^^^ thats what i did and it worked fine... if you notice the abs and seat belt lights are in different spots as well. so just swap the gauges and your good. keep all your old ones incase you want to sell your cluster so you can put everthing back.
Boofster
Jan 5, 2004 02:06 PM
AK94GSR
Dec 25, 2003 09:59 PM
EM1 Loi
Aug 21, 2003 01:15 AM
obd2gsr
Jul 29, 2003 12:24 PM
genks
Jan 13, 2003 05:26 AM
