Suspension & Brakes Theory, alignment, spring rates....
front end wheel bearing replacement
Old Mar 14, 2008 | 12:35 PM
x9cmy's Avatar
Default front end wheel bearing replacement
I need to replace my front wheel bearings. Would it be simplier and more cost effective to replace the entire assembly myself or struggle with replacing the bearings. I have a 2002 civic ex 2door. Any help or experience related answerss would be greatly appreciated.
Old Mar 15, 2008 | 09:11 AM
Mike_C's Avatar
I think you're asking if it'd be easier to replace the entire knuckle/arm? It would be easier, but much more expensive. Since you'll have it all undone, take the entire assembly to a machine shop along with some new bearings. Shouldn't cost you more than $50 in labor from them.
While you're at it, I'd also recommend replacing your bushings... Cheap/easy maintenance to do while you have it all apart.
RacerTim
Sep 10, 2010 05:44 PM
taylorjohnson11
Nov 14, 2007 07:40 PM
wrx'n you
Sep 16, 2006 11:30 AM
petergriffen
Aug 11, 2006 08:44 PM
Spectrum24x
Apr 6, 2006 03:31 PM
