05' rsx fog light switch harness quick help?
I brought them on ebay jdm yellow fog. I'm having trouble with the switch harness. The instruction is telling me to locate the 12 pin connector of my switch harness but there isnt any 12 pin connector. This is my only problem. Have anyone done their fog lights on 05-06 with a 12 pin?? or is it the wrong harness i have? let me know. thanks
i forgot to mention, it s a jdm fog light off ebay. from nana outpost.
Modified by 951dc5 at 11:40 AM 3/14/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms »</TD></TR><TR><TD CLASS="quote">go on CRSX and look up my name.</TD></TR></TABLE>
sorry but i cant find u there?
looks like i might have to do some work here. if there is no 12 pin, then its that simple. you dont have to connect it. do you have everything else plugged in correctly? you should have a white with brown connector going into the interior fuse box, the other brown connector going to the hanging brown connector in front of that fuse box. if you have a base, then you need to connect the white plug into the spot where the green 6 pin is. the other white plug connects to the green 6 pin plug you removed. lastly, you should have a green switch plug and a ground. those are obvious.
yeah but i'm having a problem where this one wire of a terminal that supposed to go with the 16 pin connector from the top of the steering column. I did everything and still no fog light shines. checked all fuses. i already bridged with my headlight so oh well.
GSR_96814
Sep 21, 2006 01:42 AM
