Which Diff bearings with LS/B16 Quaife into GSR case?
Old Mar 14, 2008 | 09:20 AM
96 GSR-T's Avatar
Default Which Diff bearings with LS/B16 Quaife into GSR case?
EDIT: Figured it out
I am having a friend build my tranny for me, as he was assembling it the case will not close all the way, he said there is a 1/4" gap, we are using GSR Enclosed Diff Bearings on an LS/B16 Quaife in a GSR Case that origionaly had tapered roller bearings, is the case the problem or is it something else? The gears are B16 123 GSR 45 is that helps.
Modified by 96 GSR-T at 10:05 AM 3/16/2008
Old Mar 14, 2008 | 09:26 AM
96 GSR-T's Avatar
I gave him 2 GSR and 1 B16 Gearset, I just read that you use an 80mm Diff Shim with the Enclosed Bearings and a 79.5mm with the Tapered, could the problem lie there? I read up on this pretty good and all the answers I got were to use the thicker GSR Diff Bearings, are the GSR's the correct bearings to use?
Modified by 96 GSR-T at 2:56 PM 3/14/2008
Old Mar 16, 2008 | 05:41 AM
Turbo-LS's Avatar
Default Re: Which Diff bearings with LS/B16 Quaife into GSR case? (96 GSR-T)
according to acura there is a difference in the bearing structure but the overall dimensions should be the same. Sounds to me like your 1/4 gap is more then likely from the rod that holds the shifter mechanism together. its sometimes a pain to align properly and will not allow the cases to fully close.
Old Mar 16, 2008 | 06:05 AM
96 GSR-T's Avatar
Default Re: Which Diff bearings with LS/B16 Quaife into GSR case? (Turbo-LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-LS &raquo;</TD></TR><TR><TD CLASS="quote">according to acura there is a difference in the bearing structure but the overall dimensions should be the same. Sounds to me like your 1/4 gap is more then likely from the rod that holds the shifter mechanism together. its sometimes a pain to align properly and will not allow the cases to fully close. </TD></TR></TABLE>
thx for the reply, have not messed with it but I think we know where the extra gap is already coming from, was a simple oversight. Thx.
carlos8
Transmission & Drivetrain
Jun 13, 2015 11:22 AM
mikesrex
18
Feb 7, 2014 11:32 AM
traxxasx
Oct 11, 2011 04:58 AM
BoostN_ED7
Nov 24, 2010 02:59 PM
Rhythm
Apr 23, 2006 11:12 AM
