Por,Rust Bullett or undercoating
Old Mar 14, 2008 | 07:58 AM
siblues's Avatar
Default Por,Rust Bullett or undercoating
I was just wondering what you guys recommend I use to coat the inside of my fenders on the front of my car?I took the front end apart on my car to do the tuck and figured whileit was off I could just recoat everything to protect it and get it looking clean again.What do you guys suggest and how would you prepare the are a for the application.Thanks for the help
Old Mar 18, 2008 | 02:20 PM
siblues's Avatar
Default Re: Por,Rust Bullett or undercoating (siblues)
Bump someone has to have some info that can help me out
Old Mar 19, 2008 | 06:02 AM
Boosted Chemist's Avatar
I used por 15 to coat the bottom of my truck. Good stuff, make sure it doesnt see UV lgiht, (sun lights). WEAR GLOVES or you hands/skin will have this **** on them for weeks
Old Mar 19, 2008 | 12:58 PM
doubleshotz's Avatar
Default Re: Por,Rust Bullett or undercoating (Boosted Chemist)
I used undercoating on all four corners.
Looks great, covers overspray, and is much more durable than i thought.
Old Mar 19, 2008 | 03:15 PM
siblues's Avatar
Default Re: Por,Rust Bullett or undercoating (doubleshotz)
Well I am sure that it will see some uv light it isnt going to be exposed openly but there really is no way it can be totally blocked out.What does the uv do to the stuff anyways?Thanks for the response
Old Mar 19, 2008 | 03:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote">Well I am sure that it will see some uv light it isnt going to be exposed openly but there really is no way it can be totally blocked out.What does the uv do to the stuff anyways?Thanks for the response </TD></TR></TABLE>
Mind you my truck is lifted and the frame is more exposed than any area you plan on doing on your honda. Check out por15.com, they make a ton of coating and i suggest you spend a couple minutes checking their stuff out. They do make a top coat for por that is uv proof. Por15 is generally used to stop rust,
check this out
http://www.por15.com/prodinfo.asp?grp=CH&dept=4
Old Mar 19, 2008 | 04:35 PM
siblues's Avatar
Yeah that is the stuff I was looking at and I dont have any rust whatsoever I just want to coat that part of the car since the fenderliners arent being used due to the intercooler pipes.
Vagitarian
Paint and Body
Jun 23, 2012 06:46 AM
Agtronic
Welding / Fabrication
45
Aug 31, 2009 09:00 AM
89 CRX SI
Apr 29, 2002 07:52 PM
GSRfoedoe
Mar 27, 2002 10:23 PM
Mike D
Sep 18, 2001 12:16 PM
