Front end is Jacked
Help! I took my 93 des sol in for a new rt front axel and new front rotors. Just moved to KY from Cali and just don't have the tools out of storage, and I'm a noob. Anyway, started driving it home and got a shake in the front end, they put it back on the rack and put two different axels on the front, because now the passenger axel was jacked??? Thing that suck is these guys did not test drive before or after. So the two new "used" axels did not fix the shake. They tried balancing one of the tires, still shakes. What I know is that these guys beat the crap out of the 32MM nut on the left side because it was "Rust Welded". It was driving fine before I took it in, other that the clicking noise when I turned left. What the hell could these guys have screwed? They are scratching their heads and I'm stressing out. They think maybe the jacked the Hub or perhaps the rotors were drilled off center. Any additional thoughts?
MJ 95 del sol
10
Apr 8, 2013 02:06 PM
