installing antenna delete
is there anything special i need to know about installing the delete? only thing that ive found as far as antenna delete instructions was for integras. i just dont want to start pulling things out of everywhere and stuff ends up not working.
i think that you have to pull off the a-pillar trim and undo the wire (some kind of clip iirc) and unplug it from the extension harness next to the fuse panel. Then just un-bolt the actual antenna from the roof and pull it out slowly. the plate should just screw back down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danjensen »</TD></TR><TR><TD CLASS="quote">where did you find your plug?</TD></TR></TABLE>
i got mine of ebay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">f an antenna delete, go to a body shop shave and paint over it.</TD></TR></TABLE>
why spend all that money when you can get a delete for 10$ shipped
i got mine of ebay
beandip
Jul 30, 2004 07:08 AM
