Suspension & Brakes Theory, alignment, spring rates....
will ef tokico blues fit on my DA teg
Old Mar 13, 2008 | 11:34 PM
ef 4 door's Avatar
Default will ef tokico blues fit on my DA teg
I have an ef sedan that has seen better days., blown engine and lots of body damage. I have tokico blues with stock spring on there and wanted to know if I can put them in my DA teg. they are both 91's and from what I have seen at the suspension, both look the same? I understand that the big difference will be the travel on strut...is that correct?
Old Mar 14, 2008 | 10:22 AM
Tyson's Avatar
Default Re: will ef tokico blues fit on my DA teg (ef 4 door)
it will fit but they arent the same.
i see no reason to use them unless its a temporary situation just to get the car rolling. blues really stink.
Old Mar 14, 2008 | 01:49 PM
ef 4 door's Avatar
Default Re: will ef tokico blues fit on my DA teg (Tyson)
they r not a temp situation. just replacements for the stock.
what do u mean that "blues really stink"?
i used them before on my ef and were a bit stiff, but worked great.
Old Mar 14, 2008 | 02:41 PM
ej1love's Avatar
the ones i had said they worked on 92-00 civic and 94-01 integra.
Old Mar 16, 2008 | 12:01 AM
ef 4 door's Avatar
Default Re: will ef tokico blues fit on my DA teg (ej1love)
my tokico blues are from a ef sedan and i want to put them on my DA teg. i have not yet found any info stating if this working properly. Tyson stated that they work but are not the same. i do not know the difference......is it shock travel, length, weight capacity.....etc.
Old Mar 17, 2008 | 09:31 AM
Tyson's Avatar
http://www.ef-honda.com/ben/EFhybridsus.php
Old Mar 18, 2008 | 10:32 PM
ef 4 door's Avatar
thanks you (Tyson) for the info on the EF suspension with DA.
this info is great.
Toe_fur
May 3, 2013 01:41 PM
TURBO B
Aug 14, 2003 10:51 PM
paulzy
Jun 7, 2002 05:04 PM
