Engine boggin
Old Mar 13, 2008 | 07:44 PM
Prudz_lude's Avatar
Default Engine boggin
When i am driving between 2-3000rpm my car is bogging. I think it may be because of a bad 02 sensor. I was also told by the previous owner that the flex pipe may be damaged. It passed its out of province inspection. I would think that the place would have pointed that out if it was true. Either way i have a new header and flex for it.
My check engine light is also coming up every once in a while. Typically when i am reving the crap out of it. This is why i think it may be the o2 sensor.
What do you guys think?
Old Mar 13, 2008 | 08:57 PM
waynecoSI's Avatar
Default Re: Engine boggin (Prudz_lude)
what engine? have you checked the code when the cel is on? my car was bogging because of a bad egr and from total blockage of the egr ports. see if you can get the code, that would help narrow the problem down.
Old Mar 13, 2008 | 10:21 PM
Prudz_lude's Avatar
Default Re: Engine boggin (waynecoSI)
i am going to do that tomorrow. I have a day off so i will do that forsure. I think it may be that. I looked under the hood for the first time (a really good look) just bought it, and the dirt is so thick in there. It is like a tary thick dirt.
Old Mar 14, 2008 | 12:06 AM
fatboy1185's Avatar
Big Cat
check all your grounds and your injectors also
Old Mar 14, 2008 | 04:24 AM
Acidcrakker's Avatar
Default Re: Engine boggin (fatboy1185)
The bogging at that rpm range sounds like its EGR related. Unplug your EGR and see if that works. If it does work, than its your EGR.
Whatislove
Honda Civic (2001 - 2005)
23
Oct 15, 2011 06:30 PM
NaCk3m
Apr 9, 2007 10:11 AM
kinvid22
Jan 20, 2007 09:17 AM
CWaldrop
Jan 10, 2006 07:02 PM
kuelerz
Oct 15, 2002 01:26 PM
