zc swap automatic shifter stuck
Old Mar 13, 2008 | 06:29 PM
goose2's Avatar
Default zc swap automatic shifter stuck
did a sohc zc swap and zc ecu.now my automatic shifter will not go out of park.i know that b11is the a/t shift position wire.is there any way to wire this somewhere else to make it work?or is there a way to bypass this issue?
Old Mar 14, 2008 | 03:04 AM
crex23's Avatar
Default Re: zc swap automatic shifter stuck (goose2)
I have the same swap as you, SOHC ZC in an automatic CRX. I used the following instructions when I did the MPFI swap. There is a slight wiring difference at the ECU versus a manual tranny car. Also, what ECU are you using? If you are MPFI, you have to use a PS9 ecu out of a 90-91 Civic EX automatic, you cannot use a manual ECU in an automatic car. Hope this helps!
http://www.fourthgenhatch.net/mpfi.html
jdm.swift
Oct 24, 2010 10:27 AM
miguey310
11
Apr 27, 2009 09:39 PM
the king.
Dec 11, 2006 08:25 PM
Anthony
37
Nov 6, 2005 08:28 AM
sixtsix mike
18
Sep 20, 2004 05:34 PM
