garage booth setup...feedback if you will
Old Mar 13, 2008 | 05:25 PM
oem_certified_accord's Avatar
Default garage booth setup...feedback if you will
i'm gonna be pickin up bits and pieces for a garage setup. i'm thinkin devilbiss guns (hplv of course) 1.7-1.8mm tips for primer and and 1.3-1.4 tips for base and clear. compressor will be the 33gal vertical craftsman 1.6hp 150max psi
i do panel painting, so i of course take everything that is removable off and paint it by itself like most do. there will be filters and liners and a wet floor all that bs.
just wondering if there will be any probs with the 33gal (i doubt it though i see a lot of you with them around here) but if heavily favored i will spring for a 60gal.
feedback and comments, tips and guidance, and flames are all welcome. kthnxbye
Old Mar 13, 2008 | 08:25 PM
kelviiv's Avatar
i would also like to know
Old Mar 13, 2008 | 09:55 PM
iam7head's Avatar
Default Re: (kelviiv)
i painted mine with a 60, i wouldnt do it on anything small. you pay more now but you save on down time and labor.
with good/proper tool it's only hurts when you pay for it, but with crap tool you are in pain every time you use it
you might get aways with a 33 with paint but not with a DA sander
1.7 is kinda too big for primer btw
Old Mar 14, 2008 | 05:14 AM
ejwan's Avatar
Default Re: (iam7head)
^ I disagree since i was able to paint my whole car w/ a 30 gal. But then again i have the Iwata which requires less are. I recommend you get the Iwata cuz less air consumption means less overspray especially for a DIY'er. check out my paint thread if u want ideas
Old Mar 14, 2008 | 10:13 AM
welfarepc's Avatar
i got away with a 25gal 6hp 135psi devilbiss and a low flow husky gun
if you are going to use nice guns get a compressor that can keep up
plus u will have a kick *** compressor from now on that will own die grinders and air sanders
Old Mar 14, 2008 | 01:44 PM
reactone's Avatar
Default Re: (welfarepc)
I have the 33 gal. compressor you're talking about. It will run out of steam if you don't give it a chance to keep up. I would suggest the Devilbiss GFG-670 as it is made to consume less cfms than your average HVLP.
Old Mar 14, 2008 | 03:38 PM
Default Re: (reactone)
60 gal it is. i dont mind dropping 100 more to feel secure. but i'm not gettin near the 80gal, that b*tch owns garage walls with vibration all day.
Old Mar 14, 2008 | 04:11 PM
iam7head's Avatar
Default Re: (oem_certified_accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oem_certified_accord &raquo;</TD></TR><TR><TD CLASS="quote">60 gal it is. i dont mind dropping 100 more to feel secure. but i'm not gettin near the 80gal, that b*tch owns garage walls with vibration all day.</TD></TR></TABLE>
ding ding ding
of course there will be someone somewhere in america painted their car with a 1 gallon compressor and got away with it but that is not the point of this tread. if you are in the position of buying a compressor, just consider the pros and cons.
MOST people will agree 60-80 is a good size for diyer for complete car paint.
sorry my sata sucks in air like a hog but that's what i use.
DA will take air out of the system like it's beer, you know you will be using one sometime down the line, might as well pay a tad more for it.
make sure you have 240 volts source with a good amp breaker, pair them up some good gague wries and you are good a too small compressor will slow you down, more water in the line, more noise(could be a bit(h for residental area)
Old Mar 14, 2008 | 04:16 PM
more on the electricity advice if you will. you're saying to prevent causing a short right?
not a 1st time diyer btw just never got to auto collision class on time
Mishako129
Jun 26, 2013 09:43 PM
99bbcivic
Paint and Body
Sep 7, 2010 09:36 PM
slacks
Paint and Body
May 17, 2008 06:15 PM
DesioMedia
Paint and Body
May 11, 2007 09:56 PM
CBR
Oct 2, 2002 08:44 PM
