master cylinder: rebuild or buy new?
Old Mar 13, 2008 | 02:14 PM
HondaHeddie's Avatar
Default master cylinder: rebuild or buy new?
I found a couple cars in a yard (89 prelude) that I can pull a cylinder/booster from for about 20 bucks. I searched and read that this will work fine with my rex.
should I install the master cylinder with the booster it came with?
or
should I just grab the cylinder itself($10) and put it on my DX booster?
OR
should I just buy a new one instead of rebuilding the above?
Old Mar 13, 2008 | 03:14 PM
sgallagher's Avatar
Default Re: master cylinder: rebuild or buy new? (HondaHeddie)
You should probably just buy a new one. They're not that expensive and you know its good.
I don't have a problem with j-yard parts there's just some parts I'd rather just buy new. I see some guys pulling brake pads off cars at the yard WTF!
Old Mar 13, 2008 | 04:10 PM
Default Re: master cylinder: rebuild or buy new? (sgallagher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgallagher &raquo;</TD></TR><TR><TD CLASS="quote">You should probably just buy a new one. They're not that expensive and you know its good.
I don't have a problem with j-yard parts there's just some parts I'd rather just buy new. I see some guys pulling brake pads off cars at the yard WTF!</TD></TR></TABLE>
Hence my statement that I was planning on rebuilding it, then it would not be "a junkyard part".
I have priced a crx MC and it was less than 50.
so a rebuild would be in that range, but the rebuild would be a prelude MC and I would know the part in and out. is it worth the trouble to put a prelude MC on?
I am thinking the MC may not be the issue now , cuz the pedal does not slowly drop to the floor, there is just alot of pedal travel before brakes grab. I just bled them but I wonder if the old fluid had so much crap in it that I should re-flush after the new fluid has been in the system for a few days to soak up the crud in the corners.
I could never get the micro bubbles to go away while bleeding
hybrid90
Suspension & Brakes
15
Sep 18, 2008 04:23 PM
suprmods
Oct 16, 2006 03:06 PM
latindc2
May 18, 2006 12:31 PM
92integraVTECgsr
Oct 26, 2005 05:17 PM
9civic5
Aug 7, 2003 10:28 PM
