itr suspension vs gsr suspension
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheapskate »</TD></TR><TR><TD CLASS="quote">does anybody know the defference between these stock oem suspensions? stiffness? ride hieght? damping? </TD></TR></TABLE>
All of the above, and then some.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheapskate »</TD></TR><TR><TD CLASS="quote">what are the specific differences?</TD></TR></TABLE>
What is the context?
Because I'm not going to sit here and build a list of the technical specs if you're not going to understand it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Because I'm not going to sit here and build a list of the technical specs if you're not going to understand it.</TD></TR></TABLE>
true, plain and simple the ITR suspension is better...
whoa just because i only have 2 post doesnt mean i am an idiot. i am just looking for the differences, spring rate, damping......
well i found the answers myself, so i thought i'd post them for others.
diference between rs/gs/ls/gsr and type r
http://www.team-integra.net/se...ID=39
and the difference between 96 and 98 jdm type r
http://www.youtube.com/watch?v=34H2MCPEUV8
Changes made to the Integra Type-R over the GSR include:
The following modifications have been made to the Type R's front suspension:
The following modifications have been made to the Type R's rear suspension:
Other notable difference the Type R has over the GSR:
- Lower overall ride height by 15 mm (0.60 in.)
- A new aluminum shock tower bar complements the 24mm stabilizer bar that is now equipped with ball joints instead of rubber bushings.
- The spring and damping rates have been greatly increased to improve performance handling.
- Front spring rate has been increased by 22%, with a 115% increase in compression damping, and a 70% increase in rebound damping.
- Damper mounting bushing stiffness has been increased five-fold.
- The spring has been changed from a straight-rate to a progressive-rate spring, increasing for across the entire range.
- Damping rates have been increased with compression damping settings in the progressive-valve unit increasing by 66%, and rebound damping doing up 31%.
- The diameter of the stabilizer bar has been greatly increased from 13mm to 22mm to reduce body roll.
- The rear wheel bearing span within the rear-wheel hub has been increased by 10mm. These larger bearings increase bearing rigidity by 30% and improve camber rigidity by 10%.
- Performance rods (structrual braces) have been added to the rear frame end and rear suspension lower arm.
- Body reinforcements (thicker sheet metal) have been made in several key areas, including the rear wheel housing, rear piller upper garter (c-pillers), rear roof rail upper, rear wheel arch extension, rear lower arm bracket (rear cross member), and rear damper gusset.
DG-FNR
10
Sep 7, 2008 06:14 PM
