Suspension & Brakes Theory, alignment, spring rates....
skunk2 camber kit OR oem uca?????
Old Mar 13, 2008 | 10:40 AM
tomek5x's Avatar
Default skunk2 camber kit OR oem uca?????
thread on the ball joints on my upper control arm are stripped and need to be replaced, should i get a camber kit instead? or should i replace the existing ball joint with a new one, and keep the old a-arm?
and if i were to replace the whole control arms with oem ones it would cost more then the skunk2 anyways. its a 89 crx si btw
Old Mar 13, 2008 | 05:35 PM
tomek5x's Avatar
Default Re: skunk2 camber kit OR oem uca????? (tomek5x)
Old Mar 13, 2008 | 05:38 PM
allricedout's Avatar
just get the skunk2 ones, i have them and u can perfect the camber if needed through low profile adjustments.
blowbyu24
Jun 9, 2006 03:04 AM
blbvtec
Jun 28, 2003 08:59 PM
dose
Jul 28, 2002 05:24 PM
