car wont go into gear, need some help!!!
i installed a new clutch and pressure plate into my 95 teg now the bitch wont go into gear like before the new clutch and stuff what the hell could the problem be some help please
I would just check the linkage and make sure it's hooked back up properly, the pin's in, or if you left it on while doing the clutch, maybe it got bent.......If it's fine, and your hydraulic system is good and bleed properly, you're going to have to take the tranny off again and check that you installed everything correctly, including pilot and release bearings.
Modified by cbr_ryder at 9:48 PM 3/16/2008
tallguy21
17
Feb 27, 2011 05:49 PM
