shifting problem
Old Mar 13, 2008 | 07:27 AM
BruskaNou's Avatar
Default shifting problem
problem might be i change the bushing that hold up the shifter already...
when i start the car up the car goes in to gear...but once im at the stop light...and i take the car out of gear...i have a hard time putting the car back in to first...i have to play with the shifter in order to ge the car in to gear...you think it the bushing or the shifter it self....i didnt have this problem before...
what should i do...i been having this problem for about a month now... plz help...
Old Mar 13, 2008 | 08:26 AM
Former User's Avatar
Default Re: shifting problem (BruskaNou)
When I occasionally have this problem, releasing and pushing the clutch pedal back down often helps, although I'm not sure about the cause of the problem. It has helped some, however, to change the manual transmission fluid.
Old Mar 13, 2008 | 08:55 AM
bond95gsr's Avatar
Default Re: shifting problem (RonJ@HT)
chech the bitch bolt in the shift linkage where the linkage bolts to the trans i had the same problem after my gsr swap in a 92 hatch. it totally fixed mine.
darkwater_ghost
Dec 14, 2012 11:38 AM
DOUBLExDEUCEx22
Dec 19, 2009 01:25 PM
AzntstyleZ
Jan 12, 2004 09:37 AM
96hb
Sep 12, 2003 02:10 AM
