lube for rear sway bar???
Old Jul 8, 2002 | 08:03 AM
magic hat #9's Avatar
Default lube for rear sway bar???
i'm getting a horrible creak/squeak/groan from the rear of my car when i go over bumps or around turns when either side of rear suspension is loaded independently. what kind of lube is safe for use on the swaybar bushings? and where can i purchase it?
Old Jul 8, 2002 | 08:35 AM
Doctor CorteZ's Avatar
Default Re: lube for rear sway bar??? (monkey_truckR)
are they poly bushings ?
white lithium grease maybe ? I just live with the squeaks on mine
Old Jul 8, 2002 | 08:43 AM
reefer_bob's Avatar
I just took my sway off, actually just took the mounting off, and left the endlinks. Cleaned it up all nice, wraped the hell out of it with teflon tape, put the poly back on, and bolted the whole thing back up. I found I actually had a little groan from from my rear LCA, but a little silicone spray took care of that...
Old Jul 8, 2002 | 09:01 AM
Default Re: lube for rear sway bar??? (reefer_bob)
they are stock bushings, i have never touched that part of the suspension. is white lithium grease readily available at home depot or pep boys?
Old Jul 8, 2002 | 09:08 AM
Warren's Avatar
Wrong-Way Wang
The stock bushings shouldn't squeak. Check the rear suspension for any problems.
Warren
Old Jul 8, 2002 | 10:02 AM
Asahi's Avatar
prothane has a great grease that comes with their poly bushings. Try and find some of that. . .
Old Jul 8, 2002 | 10:23 AM
reefer_bob's Avatar
Default Re: lube for rear sway bar??? (Warren)
Old Jul 8, 2002 | 01:00 PM
i do have a 4pt autopower rollbar, but it is tightened down well enough i wouldn't think it would squeak. any thoughts on de-squeaking a rollbar mount?
i'm going to put the car up on jackstands to locate the squeak but i still think it's the swaybar.
Old Jul 8, 2002 | 03:10 PM
o_Rage_o's Avatar
KY! White lithium grease works too...don't try it on the gf....
ALA s&m racing style
anyways, back on topic:
yes white lithium grease is available at your local home depot, its also very good for reservicing small ball bearing parts.
-Rage
[Modified by o_Rage_o, 12:11 AM 7/9/2002]
Old Jul 8, 2002 | 03:54 PM
Warren's Avatar
Wrong-Way Wang
Default Re: lube for rear sway bar??? (o_Rage_o)
I don't even wanna know what hole he's trying to lube up, or why.
That picture should be entitled "S&M racing: Living up to our name"
Warren
Old Jul 8, 2002 | 04:14 PM
slowassR's Avatar
ky...haha
Old Jul 8, 2002 | 05:08 PM
EPGONZALEZ's Avatar
Default Re: lube for rear sway bar??? (slowassR)
anybody see the best motoring where he lubes the sway bar bushings in between laps without the driver knowing...
i guess he said the car felt alot smoother turning
Old Jul 8, 2002 | 05:12 PM
DarthLuder's Avatar
New User
Default Re: lube for rear sway bar??? (EPGONZALEZ)
EP: How come Mugen dont include a lube for their swaybars.
Old Jul 8, 2002 | 05:33 PM
EPGONZALEZ's Avatar
Default Re: lube for rear sway bar??? (ITR GURU)
im not sure..but it should be...actually...after watching the video..lubing the bushings should be a regular maintenance item...oh wait it is...hahaha
EP-who has neglected the moobile
Old Jul 8, 2002 | 05:43 PM
DarthLuder's Avatar
New User
So what is the best lube to get out there that you can buy. My Moogen rear sway is starting to squeak alittle. Thanks for the info ep.
Old Jul 11, 2002 | 06:15 AM
to all the naysayers, it was the left rear swaybar bushing that was making noise and it was very loud/annoying. i picked up a tub of super white lithium grease at pepboys (>$3). i took both rear swaybar bushings off and lubed 'em up real nice like. i also found that one of the bushing bracket bolts was loose which probably allowed dirt/water to get in there and wash away any lube from the factory. it seems that most of the various bolts on the car come over/under torqued from the factory relative to the helms' suggestions. i lubed all the left rear side suspension bushings too; now i have the smooth quiet ride of a caddy!
!the monkey ownz bushings!
Old Jul 11, 2002 | 07:38 AM
AssPenny's Avatar
Joon Joon
Suspension & Brakes
Jun 29, 2010 10:21 AM
Flux
Jul 1, 2004 03:59 PM
CYBEREXII
May 27, 2003 10:00 AM
wakaru
Jul 20, 2002 03:39 PM
