help with front rotor replacement{1st time}
Old Jul 8, 2002 | 07:57 AM
sleeperaccordv6's Avatar
From: west Ft.Worth, Texas, the big one in the center
Default help with front rotor replacement{1st time}
I've ordered some powerslots and some AEM brake pads and
am wondering what the step by step would be?and if ya'll
know any special tools I may need would be appreciated.
This is my first time to do this, so be gentle{heheh}no flamming.
I did a search and came back with nothing...
Old Jul 8, 2002 | 08:50 AM
John's Avatar
New User
Default Re: help with front rotor replacement{1st time} (sleeperaccordv6)
https://honda-tech.com/zerothread?id=223096
Even though the procedure was done on my 5G, the process is still the same.
Old Jul 8, 2002 | 09:47 AM
TypeSH's Avatar
Default Re: help with front rotor replacement{1st time} (DunReit)
Are the 6th gen V6 rotors rotor-over-hub? I think that would make it much easier and reduce the # of steps vs the step by step guide you have for the 5th gen.
Old Jul 8, 2002 | 10:42 AM
John's Avatar
New User
Default Re: help with front rotor replacement{1st time} (TypeSH)
Crap, I think you're right.
John, who's brain is still struggling to recover from the weekend...
Old Jul 8, 2002 | 10:49 AM
Brandon's Avatar
Life is Suffering
See what drinking does to you. At least you werent working on your car...
Old Jul 8, 2002 | 10:53 AM
call me stupid but, what is hotor-over-hub,or hur-over-rotor?
Old Jul 8, 2002 | 10:56 AM
John's Avatar
New User
Exactly how it sounds. The hub is over the rotor (4G & 5G). See photo, notice hub bolts into rotor.
Now a rotor-over-hub (floating rotor) has the rotor on top of the hub. Thus it's easier to change your rotors.
Old Jul 8, 2002 | 11:03 AM
so what your saying is that mine is rotor-over-hub, and is easier to work on than what I just read? I was starting to get worried as I was reading that.
Old Jul 8, 2002 | 11:05 AM
John's Avatar
New User
Yeah, you won't have to use the slide hammer. Does anyone have a photo of the floating hub design? This is the only image I could find (since I do have other work to attend to...)
Old Jul 8, 2002 | 11:07 AM
4doorH22's Avatar
Oh yeah yours will be easy. Once you've removed the caliper (probably two 17mm bolts) the rotor should only have 1 or 2 philips screws holding it. It might be fused to the hub and require hammering or prying off. Um maybe you don't even need to remove the caliper to swap rotors, just lift the pads... I don't remember.
Old Jul 8, 2002 | 11:10 AM
Default Re: help with front rotor replacement{1st time} (4doorH22)
If I know the rotors are warped are they going to be harder to get off the hub?
Old Jul 8, 2002 | 12:05 PM
smokin rubber's Avatar
no that alone should not make them harder to remove. I would suggest getting a impact driver, it should be around $30 at home depot. you whack it with a standard hammer and it will help release the bolt/screw that is frozen in place without damaging or striping the bolt/screw.
preludeNApower
Sep 6, 2011 01:01 PM
Needaprelude
Feb 28, 2009 04:42 PM
skimeast1982
May 15, 2006 08:06 PM
fw190bvi
Apr 20, 2005 01:56 PM
blackssvtex
Nov 13, 2003 06:43 PM
