Will an OBD1 distributor work on a first gen B16A?
I have a first gen B16A (non-OBD) in my car and need a distributor? I'm just wondering, do you have to find an OBD0 distributor or will and OBD1 work?
Thanks in advance!
Thanks in advance!
The obd1 distributor will not fit the mount of the distributor location of the engine.Concerning the distributor plug,it still won't fit but you can wire it without using the plug.But still,you'll have to look for an obd0 only.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baulum »</TD></TR><TR><TD CLASS="quote">The obd1 distributor will not fit the mount of the distributor location of the engine.Concerning the distributor plug,it still won't fit but you can wire it without using the plug.But still,you'll have to look for an obd0 only.</TD></TR></TABLE>
thats what i thought too.
I have a ?? If someone could help i would highly appriviate it!!!! I have a 91 integra with b16a head with b18c gsr motor im using a pr4 ecu im not sure if its the right one or what but my car seems to turn on then die out right away i changed the fuel filter check the fues fuel injectors and nothing gas runs thru the line can any one help? Car stays on for bout 5 seconds when i put straight gas to the carborator n like 2 seconds tryna start it regular plz help
What? I have an OBD0 b16 long block in a 96 EK. OBD2 distributor bolted right up.
Honda Sport
Oct 4, 2015 01:25 PM
