Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
225 in the back would fit there?
Old Mar 13, 2008 | 05:43 AM
maxogsr's Avatar
Default 225 in the back would fit there?
Hi guys!
I use to run 205 in autoX on my gsr teg... I would like to go to 225/50/15 on V710 but i'm concern about clearance in the back...Can't find friends here that have run that set up.
Here's my set up in the back:
GC + koni yellow
-2.25 camber
1/16 toe in
Enkei RFP1 +41 offset
I know I can roll my quarter but I'm more concern about the rear trailing arm...
Anybody knows someone that has fit 225 V710 Kuhmos there?
Modified by maxogsr at 6:56 AM 3/13/2008
Old Mar 13, 2008 | 06:22 AM
Lo-Buck EF's Avatar
Default Re: 225 in the back would fit there? (maxogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxogsr &raquo;</TD></TR><TR><TD CLASS="quote">
yes.
would be best on a +38 offset wheel
Old Mar 13, 2008 | 06:45 AM
thawley's Avatar
I have run those tires with a 38mm offset on my EF. There was very minor rubbing in the rear trailing arm during cornering, but the damage was limited to just rubbing the paint off and creating a small bare spot. The fender lip side was the bigger issue. There was a good bit of hammer work as I recall and then some smoke for the first lap or two. Those rear fenders have three or four layers of steel in some places and are a bitch to roll properly. A very BFH was required.
I found the 710s to be faster than the Toyos by a noticeable bit, though not stratospherically so. They are also less durable. I flat spotted one much more easily than I expected. My fault, to be sure, but I've screwed up just as bad with the Toyos and not gone straight down to the cord.
Seems like it would be a good auto-x tire.
Old Mar 13, 2008 | 08:40 AM
Lo-Buck EF's Avatar
Default Re: 225 in the back would fit there? (thawley)
ef has way less space rta to fender than integra. everyone with a dc2/4 chassis is using 38-35 offset for the most part with 225s. kumho, toyo, hoosier, hankook.
my ef only rubs the outside with the toyos 225 50 on a +38. when i put +40 in the back its fine. but i have da trailing arms. they have a differaant offset than stock civic and crx si. but 225 45 hoosiers on stock ta would hit the ta and stick out past the quarter on a +40 offset.
Old Mar 13, 2008 | 09:32 AM
00R101's Avatar
Default Re: 225 in the back would fit there? (Lo-Buck EF)
Stock teg with stock offset will not fit 225 Hoosiers or Kumhos in back (rubs on LTA). If you reduce the offset or use 10mm spacers it should fit.
Old Mar 13, 2008 | 11:58 AM
mc-integra111's Avatar
I have a DA and I can fit a 225 V710 in the rear with +38 and +40 offset rims. I have no issues with the rear trailing arm at all. To clear the fender, I did have to do some significant rolling.
Old Mar 27, 2008 | 02:14 PM
maxogsr's Avatar
I think I'm gonna ride an ackward set up...hoosier A6 225/45/15 in front and 205/50/15 in the back... I'll drive it like a fork lift!
Any feed back with this set-up?
Modified by maxogsr at 3:22 PM 3/27/2008
Old Mar 27, 2008 | 04:19 PM
solo-x's Avatar
Default Re: (maxogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxogsr &raquo;</TD></TR><TR><TD CLASS="quote">I think I'm gonna ride an ackward set up...hoosier A6 225/45/15 in front and 205/50/15 in the back... I'll drive it like a fork lift!
Modified by maxogsr at 3:22 PM 3/27/2008</TD></TR></TABLE>
It won't be as loose as you think. I'll be running 275's up front with 205's out back, just like Rodney did on his EG SM monster.
Old Mar 27, 2008 | 04:58 PM
jeffhaut's Avatar
Default Re: (solo-x)
ive done the 225 710 on a 15x8 38 off wheel on my dc
roll the fenders a fair bit, and i still needed about 2mm of spacer to make it not hit RTA
Old Mar 27, 2008 | 05:40 PM
maxogsr's Avatar
Default Re: (jeffhaut)
Even if i'm stiffer in the back? I have 350fr and 450back+ a 22mm. I'm use to "R" on track but not in autoX. My first year in SM... I use to run on 215/45/16 Rt615 in STS the 3 last years.... It was alwready loose...
Old Mar 27, 2008 | 05:46 PM
Lo-Buck EF's Avatar
just put them on and find out. at an autocross, ther realy isnt much use for 225 out back. on track its a differant story. but if u can drive r-comps on track, i dot see why you cant do it at an autocross.....
Old Mar 27, 2008 | 05:48 PM
djphoebus's Avatar
Don`t worry about it MAX!
No matter what tire you use this summer you`ll be fast in Quebec...Well... fast to finish second... ...haha
Old Mar 27, 2008 | 05:49 PM
jeffhaut's Avatar
i ran SM with 650 frt 600 rear in my DC. when i say roll i dont mean my fenders are now protruding from the car, but the inner lips are pretty much flat now
also check the seam of metal in the front fenders under the fenderliners, under hardbraking and turning the seam added a 3rd grove to my right front V710 and i cut a portion of the fender liners out and hand rolled the tabs that hold the liner in as well. its all in the sake of fastar tho so its all good
maxogsr's Avatar
Default Re: (Lo-Buck EF)
Not affraid...I would say anxious!
Old Mar 27, 2008 | 05:51 PM
maxogsr's Avatar
Default Re: (djphoebus)
Well we will see that pretty soon... Can't wait for that battle for 1st place!
Modified by maxogsr at 4:04 AM 3/28/2008
Old Mar 28, 2008 | 06:53 AM
thisisntjared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo-x &raquo;</TD></TR><TR><TD CLASS="quote">
It won't be as loose as you think. I'll be running 275's up front with 205's out back, just like Rodney did on his EG SM monster.</TD></TR></TABLE>i thought you were in sts wouldnt that put you all the way to stu?
Old Mar 28, 2008 | 12:32 PM
maxogsr's Avatar
I finally made up my mine... I'll deal with my loosse rear end! A6 225/45/15 fr 205/50/15 rr... Should get my tire next week!
elfather
Mar 9, 2007 03:00 PM
JDMG3
Mar 21, 2006 01:03 PM
NiceDc2r
Sep 1, 2005 03:02 PM
yellow blur
Jul 3, 2005 12:26 AM
JG90CRX-Si
Jun 9, 2004 08:16 PM
