need help with f22b2
Old Mar 12, 2008 | 10:36 PM
krytoi's Avatar
Default need help with f22b2
i got a 97 accord with f22b2 auto and my main seal leaks oil real bad can some one help me by showing how i can unscrew the bolt on the big pulley. ( the one that is spinning the timing belt) the bolt thats connected to the crank . well thanks for your time
Old Mar 13, 2008 | 07:21 AM
hondadude's Avatar
Default Re: need help with f22b2 (krytoi)
That crank pulley bolt on the 94-97 can be a real pain in the a$$.
Best thing you could do is stop by a truck garage with a 19mm socket and get them to loosen it with a 3/4" or 1" impact, then retighten it with a smaller impact or by hand, and go directly to where you are going to do the work.
As far as the oil leak, I've seen many more oil pump gaskets leak than front crank seal. Also you should check the front counterbalance shaft seal and be sure it has a retainer on it.
If the cam seal is leaking there is usually oil on the "shelf" behind the timing cover on the rear of the block.
z6htch
10
Nov 1, 2009 04:55 PM
lugoismad
May 30, 2009 06:59 AM
suspendedHatch
Jul 14, 2005 08:01 PM
ludelvr
Dec 19, 2003 11:01 AM
