short shifter
a wats up guys i have a h22 in a 93 civic im tryen to find a short shifter but in not sure if im using the prelude shifter or a accord shifter does it matter are they the same or different also anyone know of a good one to get?
THANKS H-T
THANKS H-T
when you/or previous owner did the swap, I take it you used the stock shifter and cables from the Prelude? If so, I would go with either a PSPEC Tunning or Forbidden Motorsports shifter
well thats wat im not sure about wen i bought the swap from the guy i kinda remember him telling me the shifter was from a accord but as i remember he knew nothing so he could of been wrong but wat im askin is if there the same shiter /part#
I can tell you that the shift levers from the 90-93/94-97/98-02 Accord and 92-96/97-01 Preludes all have different part numbers.
90-93/94-97 Accord and 92-96 Prelude look similar to each other while 98-02 Accord and 97-01 Preludes look similar.
I believe by adding a part to the 92-96 Prelude shifter you can make it work in the 90-97 Accords. You would have to dig up some old threads probably to find that info. But by looking at part diagrams on SLHonda or Majestic Honda I'm sure you can figure out which part would be needed.
Actually, after thinking about it... by comparing the shifter in the car to the diagrams online, you may be able to narrow it down as to which shifter you have in your car. I believe it's the mounting point for the upper most shift cable that is visually different between the Accord and Prelude.
The forbidden shifter is supposed to work on 90-93, 94-97 accords and 92-96 preludes. To make it work on an accord, there is one part that you have to purchase from honda. If you contact jeremy at forbiddenmotorsports.com, he'll let you know what part you need (and he's a good guy, too, so he might even be able to help you figure out which shifter assembly you have!)
hoychristian
Transmission & Drivetrain
10
Feb 9, 2016 03:19 AM
