custom exhaust made check engine and maintenance lights come on
Old Mar 12, 2008 | 05:43 PM
newtothescene's Avatar
Default custom exhaust made check engine and maintenance lights come on
I got a custom 2.25 inch exhaust made and about 4 hours afterwards both lights came on. Can anyone tell me what the deal is?
Old Mar 12, 2008 | 05:51 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: custom exhaust made check engine and maintenance lights come on (newtothescene)
go into the FAQ and read on how to reset your maintenance light. It's mileage related and was completely coincidence.
since you never listed you year I don't know if your Accord is OBD1 or OBD2. So I'll say this... if it's pre96 then go into the FAQ and see how to pull the CEL code(s). if it's 96+ go to AutoZone, or some other parts store, and get it scanned for free.
Then do some research on what the code(s) mean.
Old Mar 12, 2008 | 10:51 PM
Soc@lep3's Avatar
dont really know if its the same with the accords, but wen i had my ep with a testpipe, i had to mod one of the o2 sensors to remove the light.
Old Mar 13, 2008 | 12:32 PM
Default Re: custom exhaust made check engine and maintenance lights come on (TouringAccord)
Ok. Its a 98, and the folks at auto zone said my cat is flowing more than usual. Guessin my cat is past its prime.
Old Mar 14, 2008 | 02:59 PM
jdmaccord1988's Avatar
Default Re: (Soc@lep3)
i had the same problem and if there is not o2 sensor set in the the check engine light remains on and if you remove it using the scanner in a couple of minutes it will return..so im guessing its your o2 sensor next to the cat..
Old Mar 15, 2008 | 11:28 AM
Default Re: (jdmaccord1988)
I dont think its the sensor. I upgraded to iridium plugs, performance wires/coil/cap and rotor, and the light went off. Maybe it was tune-up time.
Meemo Foo!
Jun 16, 2016 02:37 PM
almostboostedgsr
Mar 1, 2007 06:08 AM
nos4a2si
Feb 11, 2005 11:33 AM
nexus da9
Mar 2, 2004 03:36 PM
PolySquared
Jan 17, 2002 01:43 PM
