f.s h22 swap crower, skunk2, bloxs, cometic, arp and more
Old Mar 12, 2008 | 04:10 PM
erocksitr's Avatar
Default f.s h22 swap crower, skunk2, bloxs, cometic, arp and more
97 jdm h22a swap only 800miles on it
hasport mounts for an eg
pasenger axle is raxle other side is da axle
blox valve train and valves
greddy timing belt, hondata i/m gasket b and m fuel presure regulator
balance shaft removal kit already installed
manual timming belt ajuster
balanced f22 crank and rods, jdm h22 pistons
arp head studs honda bearings
new oem oil pump and water pump valve job was also done when motor was built
obd1 wireing harness
xtd 6 puck cluth and 12 lbs flywheel
lsd h22 tranny no grinds
most gaskets where replaced in the motor
selling to rebuild a 2000 py itr
brand new crower stage 3 cam, skunk2 i/m and skunk2 cam gears not installed
make offer no lowballers plz
Modified by erocksitr at 8:10 PM 3/12/2008
Old Mar 13, 2008 | 09:04 PM
NegroEk's Avatar
Default Re: f.s h22 swap crower, skunk2, bloxs, cometic, arp and more (erocksitr)
!pmuB
erocksitr
Mar 17, 2008 06:26 PM
2001accord
Mid-Atlantic (Sales)
Mar 19, 2006 10:11 PM
2001accord
Mar 18, 2006 03:34 AM
