Honda S2000 Honda S2000
Where do I hook up this plug? (Hardtop issue)
Old Mar 12, 2008 | 03:57 PM
shamoo's Avatar
Will you make something up for me please?
Default Where do I hook up this plug? (Hardtop issue)
I'm installing the hardware for the OEM hardtop I just received. Everything's flowing smoothly EXCEPT for what seems like should be the simplest thing.
Where does the harness from the driver's side catcher plug into? Here are a few pictures to show what I'm looking at. The instructions say to look for the only available open 2 pin connector near the corner of the door opening. There is nothing there at all. Is there something different in mine? I have an 07 and noticed that I did not have to modify any panels to get the catchers to fit.
This is everything that I see when I'm looking for the open connector. There is nothing inside the "hole" behind the seat, and there is nothing in that mess of wires by the gas cap puller. The little red colored wire goes into a very wide 2 pin connector that's being used. The little black wire that goes into the gas puller area is a ground from the main harness.
Here's another somewhat blurry shot from the top (catcher isn't installed in this picture).
Any help will be appreciated. I already finished the passenger side, and that took me only 10 minutes. I want to be able to finish this quickly, as I'm itching to get it on and take some more pictures.
Thanks!
Old Mar 12, 2008 | 04:25 PM
iam7head's Avatar
Default Re: Where do I hook up this plug? (shamoo)
defroster plug?
Old Mar 12, 2008 | 04:35 PM
LAS2K's Avatar
Default Re: Where do I hook up this plug? (iam7head)
http://www.s2ki.com/forums/ind...10158
Old Mar 12, 2008 | 04:54 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">defroster plug?</TD></TR></TABLE>
Not sure, there are a couple of harnesses that are included in the kit. I'm working on the hardware now and will put the top on on the weekend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">http://www.s2ki.com/forums/ind...10158</TD></TR></TABLE>
Ironically, I have that printed out and was using that as well as Hardtopguy's instructions. Unfortunately, they did not help. There is no free open plug in this area on my car. Not sure if this picture will link correctly.
EDIT: Guess not....but! I figured it out. See below post.
Old Mar 12, 2008 | 04:59 PM
shamoo's Avatar
Well, I didn't figure it out. A member on s2ki pointed out something quite obvious.
I need the hardtop subharness (Y-harness) to connect everything. It was actually included in the hardtop kit and I wasn't sure what it was for. I thought it was extra .
http://www.jayhondaaccessories...p.pdf
Stay tuned for a full how-to for the HT install.
Old Mar 12, 2008 | 06:17 PM
Sikocivic's Avatar
You mean like this;
http://www.handa-accessories.com/s2000/s2k2top.pdf
93egboosted
Mar 18, 2009 07:27 PM
Dead CIVIC
Jan 28, 2008 03:40 PM
jwbnavy
Dec 4, 2007 02:20 PM
j spec
Jul 30, 2006 04:57 PM
West Werks
Mar 10, 2005 08:10 AM
