vtec rotor upgrade
You can use the Spoon 4-Pot Piston Calipers on the 4thGen VTEC Rotor and Knuckle also.
You'll need VTEC 11.1" Rotors from a 4thGen VTEC and that's all you'll need for a Spoon Caliper Setup.
Nope, take S Model Rotor off and put VTEC Model Rotor on.
Only thing that would need to be different would be the Calipers and Brackets. You can't use the Stock S Model Calipers and Bracket on the VTEC Rotors.
so what ur saying is i could buy vtec brake upgrades for my car if i get the vtec mounting bracket?? and how much difference is there between the vtec and the s model rotors
Eh, I'm not sure what you mean at first. But here's some spec's..
4thGen Prelude S & Si Model have 10.2" Rotors.
5thGen Prelude VTEC Model have 11.1" Rotors.
4thGen S & Si Model Calipers are a different size than the VTEC Model Calipers, but they have the same size Piston.
The Brackets are also different between the S & Si Models and the VTEC Model for obvious reasons, to allow for a larger Rotor.
The S & Si Bracket will not fit over the VTEC Rotor.
If you hit up your local parts store, you should be able to get rebuilt calipers for the Vtec model with brackets, and pick up a set of rotors and pads, then just bolt everything on. I will be doing this on my base model next month.
Here are the calipers I will be using:
http://www.napaonline.com/mast...Remfd
superturboprelude
Jan 12, 2004 05:42 AM
