1996 Honda Accord Charging system problem
Old Mar 11, 2008 | 09:19 PM
Spud1's Avatar
Default 1996 Honda Accord Charging system problem
I have a 1996 Honda Accord EX, the other day for some reason the system stopped charging. Battery light did not come on, but the car ran on battery until it was drained. Had the alternator checked at four different shops and it passed. Battery checked bad. Purchased new battery, put the alternator back in car ran fine for a day. Last night lights started dimming and eventually car stopped. Jumped started drove home. Today took alternator and starter off, and had them checked. Both checked out fine. Decided to replace the alternator just in case. Car started, but about 10 minutes later RPM went dropped and it died again. It seems that the charge is not recycling between the battery and the alternator. Help. Thanks
Old Apr 29, 2010 | 12:02 PM
dgpost123's Avatar
Default Re: 1996 Honda Accord Charging system problem
I have a 1996 accord ex. After getting 2 bad re-man alternators from the parts house, I finally got a good one. One problem though, for some reason, after hooking up the new one, something in the system has partially shorted the alternator out leaving it with a 9-10 volt output instead of the usual 13.5- 14.5. Could the problem be the ECM, which I think is where the regulator is, or the load dist. box? I'm stumped. Thanks-----------Dave
Old Apr 29, 2010 | 12:39 PM
TheMuffinMan's Avatar
He knows where you live!
The output from the alternator across the battery terminals while car is on should be around 14V.
Testing that will tell you if it is working. If you bought a Advanced Auto reman alternator, I'd put money on it being a POS.
*edit* Just f'n realized the post is over 2 years old
HornsManiac
Jul 6, 2016 06:53 AM
khansen
Mar 17, 2014 11:03 AM
curtie94
Feb 7, 2011 11:04 PM
Nick6
Aug 18, 2010 05:26 PM
SDHonda
Feb 1, 2008 06:50 AM
