itr headers?
Old Mar 11, 2008 | 08:46 PM
CuzzinDohc's Avatar
Default itr headers?
Will Itr headers fit my b18b? if it does fit does it make any diff?
Can anyone fill me in on any info Thanx.
Old Mar 11, 2008 | 09:00 PM
Pat_S's Avatar
Default Re: itr headers? (CuzzinDohc)
Yes, it will fit. You will need to have a compatable converter and cat-back system.
Old Mar 12, 2008 | 03:44 AM
crazyguy's Avatar
Default Re: itr headers? (Pat_S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pat_S &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it will fit. You will need to have a compatable converter and cat-back system.</TD></TR></TABLE>
it will bolt on to your engine.but the down pipe flange will be off.it will bolt on to your intermediate pipe too. u need to have a muffler shop cut/extend and weld for you
Old Mar 12, 2008 | 07:06 AM
Padawan's Avatar
Darth ModerVader
What ITR header are you referring to?
Old Mar 12, 2008 | 09:38 AM
nautica_t's Avatar
yeah many variations.
jdm 96 spec 2 piece 4-2-1 (i believe)
jdm 98 spec 1 piece 4-1
usdm 2 piece 4-2-1
Old Mar 12, 2008 | 09:44 AM
dickdragon's Avatar
i used a dc sports jdm itr header on my 99 obd2 ls. everything bolted up fine . the only modification i did was i had to drill 2 new holes for the cat to collector. now the exhaust ports don't exactly line up perfect, but they do bolt up!
Old May 5, 2008 | 10:41 PM
BillyBoom29's Avatar
I have the 98 jdm spec headers w/ pwjdm test pipe. I had to get the oem itr collector gasket. I also have a 2 1/2 magnaflow high flow cat w/ blox flange.
The ITR headers can fit any B series. 90-01, vtec/non vtec.
99_EM1
Feb 8, 2010 07:46 AM
CLvtecGSR98
Jan 31, 2003 08:44 PM
SilverDc2
Oct 23, 2002 03:06 PM
ILOVEGIRLS
Sep 17, 2002 11:57 AM
2fastGSR
Oct 2, 2001 07:55 PM
