awsome civic for sale
The car is a 1993 civic ex.
Engine:
It has only 850 miles
D16z block fully built with sleeves
JE pistons 9:1 compression for turbo
Crower connecting rods
JDM rod bearings, main bearings
JDM M.L.S. head gasket
Crower cam shaft for turbo setup
Crower valve spring with titanium keepers
Moroso aluminum oil pan with dual baffle for better cooling
Venom aluminum intake manifold
Big throttle body
MSD 550 fuel injectors
AEM aluminum/adjustable cam sprocket
Energy Suspension solid motor mounts
AEM high flow fuel rail
Venom High flow fuel pressure regulator with oil filled gauge for more accurate reading
Aluminum overflow / blow by catch can
Custom/Modified valve cover to fit catch cans.
Haletch E6K fuel and ignition management
2 Bars Map sensor (2 bars=24 psi)
Im also throwing a laptop to adjust the Haltech
Percy’s high performance Exhaust Temperature gauge (digital)
MSD 6al ignition box
MSD 8mm ignition cables
MSD distributor cap
MSD Blaster Coil
MSD 2 step for staging
Drag generation III turbo kit with
T3/T4 tubonetics turbo
HKS high sequential blow off valve
TiAL Sport 38mm External Wastegate
Turbo X 2 stage boost controller
Upgraded sparco intercooler
Tubular tig welded Turbo manifold with external wastegate port
Alunimun radiator
Sump in the Fuel Tank done By Acosta motorsports
High pressure/Flow Bosch fuel pump (2 of them)
High Flow aluminum fuel Filters (2 of them)
Size 10 high pressure braided line from the fuel tank to the engine
Size 8 return line, fittings elbows and connectors.
I spent $1200 just in fuel lines, fittings and elbows
Transmission:
Clutch Masters 9 pounds aluminum flywheel
A.C.T. 6 puck bronze clutch disc and A.C.T. Extreme pressure plate.
Suspension:
Tokico Ilunima 5 way adjustable struts and springs.
Brembo cross drilled and slotted rotors front and back with brake pads.
Russell braided brake hoses for better stopping.
99 Si suspension.
99 Si Rims with Michelin tires
Energy Suspension control arms bushings and sway bar links
Energy Suspension trailing control arms bushings
Addco rear sway bar
South Florida Performance adjustable upper control arms
Moog performance ball joints, inner and outer tie rods
Ingals rear adjustable rods
DC sports front strut bar
DC sports rear upper strut bar
DC sports rear lower bar
Inside:
R 1 bucket seats
Auto meter phantom gauges
Oil pressure
Volt meter
Boost
Temperature
Air / fuel
Shift light
Indiglo cluster
Short shifter with type R ****
Viper alarm with motion sensors
Sony xplod radio
Pioneer speakers
Outside:
The car was painted in silver paint code NH623M
Carbon fiber hood
I also have the stock hood in the same color as the car
Wing West big mouth front bumper
99 Si side skirts
Rear BMW style lip/spoiler
Front halo headlights
JDM corner lamps
JDM rear clear/red tail lamps
As you know all civics ex models come with sun/moon roof
I Dynoed the car at 330hp to the wheels
The best time I’ve done was 12.30 on the Ľ mile
This car is stupid fast and you won’t regret when you drive it.
If you see any part(s) that you like send me an email and we can talk
my email is mvcivic@yahoo.com
for pics send me an email also
Engine:
Big throttle body
MSD distributor cap
MSD Blaster Coil
Alunimun radiator
Transmission:
Suspension:
99 Si suspension.
Addco rear sway bar
Inside:
R 1 bucket seats
Oil pressure
Volt meter
Boost
Temperature
Air / fuel
Shift light
Indiglo cluster
Sony xplod radio
Pioneer speakers
Outside:
Carbon fiber hood
99 Si side skirts
JDM corner lamps
OP, i have one question....
does this look like a classifieds section? does it?
also, where are the pics? any ad worth the bandwidth, regarding such a car as yours listed, should have accompanying pics!
locked.
locked.
ZEX Man
Nov 30, 2004 06:55 AM
NyQuiL
Sep 13, 2003 01:42 AM
NyQuiL
Sep 5, 2003 08:50 AM
