*FS*FS* EJ1 part out // Full AC System // B18b1 and more!!
[size=2]This is not a commercial post!
Please BUMP if you view!!
<FONT COLOR="green">AIM</FONT> = ShonuffLoveBoost
<FONT COLOR="blue">EMAIL</FONT> = jaydubya04@gmail.com
<FONT COLOR="purple">CELL</FONT> = 714-351-4164 call and leave a message
<FONT COLOR="crimson">1995 Horizon Gray Ex (EJ1) 190k chassis</FONT>
I am almost finsihed with my project and I do not want to keep it. I am finishing it up and putting it up for sale. I have receipts for everything that was purchased after I bought the car. Some stuff was paid for in cash with no receipt, but it is all brand new. This car once belonged to "shorsh" and "spoka".
Testing Waters!!!!
1995 Horizon Gray EX Civic w/ 190k on the chassis
CLEAN TITLE
Minor dents here and there, but nothing big.
Engine/Trans
95 B18b (From Hmotors w/ est. 25k mileage)
AC and PS!!
NEW (all OEM unless listed) timing belt, headgasket, throttle body gasket, Hondata IM gasket, Full valve cover gasket/grommets, Type-R oil pump, water pump, oil pan gasket, cam seals, BDL bronze cam seal plug, cap/rotor, plugs/wires.
NEW CRV AC bracket
Intake manifold is USDM spec for an easy BAR ref pass
Purchased $180 in brand new nuts/bolts from Honda (with receipt and parts list)
Custom SS clutch line
Apexi WS2 exhaust with cat
98 JDM LS trans (SC4, from Hmotors w/ est. 25-30k... no grinds or popouts)
Bseries shift linkage with NEW ES shifter bushings (black)
NEW Exedy OEM replacement clutch.
Resurfaced flywheel
Suspension/Brakes
All the new parts listed above and below have less than 10 miles on them... keep that in mind.
GSR rear disc...
All NEW...
Skunk2 Pro-S coilovers
Skunk2 LCA
Skunk2 Pro Series+ Front Camber Kit
BLOX rear camber kit
Brembo blanks Front and Rear
PBR pads Front and Rear
SS brake lines Front and Rear
EARLs solo bleeder brake bleeders Front and Rear (for easy 1 person bleeding)
Ebrake cables
New brake and clutch fluid as well as ps fluid
Interior
Stock gray interior. Full interior. I have recently cleaned the seats and am in the process of cleaning the carpet as best as I can. All interior panels were taken out so I could clean EVERYTHING!
CONS!!!!
Driver side fender was damaged. This will be replaced by a black fender (will need repaint).
Hood latch is not working properly and will be fixed before I sell.
Radio is somewhat jacked. I have a full stereo system I got for xmas a year or 2 back that I didnt install (BNIB, headunit and front/rear speakers). Will throw in if I get a good offer.
I have a stock OEM front bumper and lip that I might throw in also. I know this is HT so a lot of people will lowball.
The motor has less than 30K on it with all brand new parts!!
<FONT COLOR="crimson">EJ1 Rear Seats *Gray*</FONT> <FONT COLOR="green">SOLD </FONT>2 Me...
<FONT COLOR="crimson">Custom SS Clutch Line *Clear*</FONT>
I had two of these, one for each of my cars. As I have stated before I am stripping one so one has to go. I purchased this off of "Luserkid". These are a great replacement for the stock setup. Made with EARL fittings and wrapped in clear tubing (some what CF look). Gives the engine bay a clean look. These will work with all B and D series LHD cars with hydro trans. Only looking to get what I paid since it has never been used - <FONT COLOR="green">$</FONT>65
http://i186.photobucket.com/al...4.jpg
http://i186.photobucket.com/al...5.jpg
http://i186.photobucket.com/al...2.jpg
http://i186.photobucket.com/al...3.jpg
http://i186.photobucket.com/al...1.jpg
<FONT COLOR="crimson">BDL Cam Seal Plug</FONT>
I have one cam seal plugs to sell. These were purchased for my stock B18b1 build and my 81.5mm B18b1 turbo build. I have sold both blocks as you have seen before so I have no use for them. They are for Honda/Acura Bseries motors. I have a Titanium cam seal plug - <FONT COLOR="green">$</FONT>22
http://i186.photobucket.com/al...i.jpg
<FONT COLOR="crimson">EARL's Solo Bleeder (Brake Bleeders)</FONT>
As I have said before I am parting out my EJ1 because I have another EJ1. I picked up two sets of these and I need to get rid of one. This pack is for front and rear disc brakes only with 1 bleeder for your clutch slave cylinder. EARL solo bleeders allow you to bleed your brakes yourself. Here is a write up my buddy did with pics and more info. Pics of mine are below - <FONT COLOR="green">$</FONT>45 shipped (set)
https://honda-tech.com/zerothread?id=2250656
<FONT COLOR="crimson">OBD1 LS Injectors</FONT>
These injectors came off my JDM B18b that I picked up from Hmotors. I have another set so I have no need for these - <FONT COLOR="green">Taking Offers</FONT>
<FONT COLOR="crimson">Random **** #1</FONT>
AC compressor off my B18b1 swap; I don't know if it works - <FONT COLOR="green">Free!!</FONT>
http://i186.photobucket.com/al...7.jpg
P2A PS Pump - <FONT COLOR="green">Taking Offers</FONT>
P54 PS Pump; No idea what its off of - <FONT COLOR="green">$</FONT>10
http://i186.photobucket.com/al...6.jpg
B18a1 Cams w/ Gears, should work with B18b/b1's - <FONT COLOR="green">$</FONT>20
JDM B18b IM; No injectors. It came off my motor from HMO. I think its an Auto IM, but still good for sensors/parts - <FONT COLOR="green">$</FONT>15
http://i186.photobucket.com/al...8.jpg
B18a1 IM; Bare and its clean - <FONT COLOR="green">$</FONT>5
http://i186.photobucket.com/al...9.jpg
<FONT COLOR="crimson">Random **** #2</FONT>
http://i186.photobucket.com/al...0.jpg
B18a/b1 Timing Belt Covers - These are off a few motors I picked up over the past year. No need for them - <FONT COLOR="green">$</FONT>10 ea.
<FONT COLOR="crimson">Random **** #3</FONT>
Water Pumps off B18b/b1's - <FONT COLOR="green">$</FONT>10 ea.
Oil Pumps off B18b/b1's; still in good condition - <FONT COLOR="green">$</FONT>10 ea.
<FONT COLOR="crimson">Random **** #4</FONT>
Water tubes w/ thermoswtich (2) // Windage Tray w/ pickup (2) // Breather Chamber (2) // Rear Main Seal; off of my B18b1's - <FONT COLOR="green">Taking Offers</FONT>
Modified by 95ProjectEJ1 at 6:01 PM 4/22/2008
Testing Waters!!!!
CLEAN TITLE
Engine/Trans
AC and PS!!
NEW CRV AC bracket
Resurfaced flywheel
Suspension/Brakes
GSR rear disc...
All NEW...
Skunk2 LCA
Ebrake cables
Interior
CONS!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoka »</TD></TR><TR><TD CLASS="quote">on that eg hood u still have the rag i left on it LOL</TD></TR></TABLE>
Haha yeah. As soon as I picked it up from you I took it home and put it in the garage. It sat covered until I took pics. Most of this ish should look familiar. Half of it is from you and the car lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nurvcom »</TD></TR><TR><TD CLASS="quote">pmed you 95projectej1 calling dibs on headlights
You have dibs for sure... pending to you
</TD></TR></TABLE>You have dibs for sure... pending to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">
yaaaaaaaaaaaaaaaaaaaaaaaaaa
pending
95ProjectEJ1 PWNS
</TD></TR></TABLE>yaaaaaaaaaaaaaaaaaaaaaaaaaa
pending
95ProjectEJ1 PWNS
pending
95ProjectEJ1 PWNS</TD></TR></TABLE>
Thank you sir.
I will clean the seats one more time this week. I noticed a few more spots once I was done. I will see how well it takes them out.
Off to bed
pending
Thank you sir.
Off to bed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorsh »</TD></TR><TR><TD CLASS="quote">are those my rear smoking seats?</TD></TR></TABLE>
Certainly are lol. Going to clean them one more time and see if it helps at all. Going to replace the rear and trunk witha custom MDF setup or some Rhino liner lol
