b20v headgasket
ok i have a stock 99-01 jdm b20b block with a stock b16 head... and i need a headgasket but im not going with the oem because of the thickness (.030) i wanna go with something a little thicker because of piston to valve clearance should i go with .050 or is that too much? i wanna get the cometic 84mm .040... is it worth losing the compression to have the insurance that a valve wont hit a piston????
Modified by Midori Green at 9:16 PM 3/11/2008
I believe that you will need to look to "Mr Gasket" for an 84mm headgasket made exactly for that application.
btw, i got your IM.....i don't use live msg services, but can correspond through email if you have more detailed questions:
deetz1@shaw.ca
deetz1@shaw.ca
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz »</TD></TR><TR><TD CLASS="quote">I believe that you will need to look to "Mr Gasket" for an 84mm headgasket made exactly for that application.
deetz1@shaw.ca</TD></TR></TABLE>
no prob.. even tho im is a little more convenient because it is instant i will email u thanks
Junkyard2000
Nov 23, 2005 11:30 AM
turbotime
Oct 15, 2005 05:55 PM
Dohcvtec59
Sep 14, 2004 05:48 PM
Black DC2
Jun 9, 2003 06:31 PM
BlackGSR
Jul 15, 2002 02:10 PM
