Quick ?, Engine Block Code on 88-91 1.5 Civic
Old Mar 11, 2008 | 03:31 PM
Nisif's Avatar
Default Quick ?, Engine Block Code on 88-91 1.5 Civic
What's the block code on the 1.5 Sohc 88-91 Civics. I believe they're dpfi motors.
I'm looking to replace a head on a D15b7 motor (93 Civic Dx MPFI), and a junkyard told me that the 88-91 Civic head will work on that motor. I was skeptical, is this true?
Old Mar 11, 2008 | 04:03 PM
hailchristian's Avatar
Default Re: Quick ?, Engine Block Code on 88-91 1.5 Civic (Nisif)
D15b1 and d15b2 are dual port • Dx and std
D15B6 is mpfi • hf
Old Mar 11, 2008 | 05:48 PM
Nisif's Avatar
Default Re: Quick ?, Engine Block Code on 88-91 1.5 Civic (hailchristian)
Great, thanks. Anyone know if any of these heads will directly bolt up to a D15b7 block with no modifications?
Old Mar 11, 2008 | 07:08 PM
1991civicd16z6's Avatar
im preety sure the 88-91 heads will all fit ...yes they are dpfi but thats just the intake manifold thats different , just throw your d15b7 intake manifold on it .... but a hf has 8 valves so you wouldnt want that ..... all others are preety mutch identical to your d15b7 ....
Old Mar 11, 2008 | 08:09 PM
Nisif's Avatar
Default Re: Quick ?, Engine Block Code on 88-91 1.5 Civic (1991civicd16z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1991civicd16z6 &raquo;</TD></TR><TR><TD CLASS="quote">im preety sure the 88-91 heads will all fit ...yes they are dpfi but thats just the intake manifold thats different , just throw your d15b7 intake manifold on it .... but a hf has 8 valves so you wouldnt want that ..... all others are preety mutch identical to your d15b7 ....</TD></TR></TABLE>
Makes sense, I knew the im would have to be swapped cause of the injectors. Can anyone verify these heads work or has done the swap? TIA
spoolinhatch123
Sep 24, 2007 08:42 AM
stock4now
27
Oct 10, 2006 03:54 PM
b16_ef
Mid-Atlantic (Sales)
Sep 25, 2006 01:52 PM
RACEPAK
Jun 13, 2005 05:32 AM
Spooled1.6L
Feb 19, 2004 02:30 PM
