Washer fluid all the way to the top of the cap? Mines Leaking?
How far up can you fill the washer fluid in the 06's? I cannot get it to fill all the way up to the cap - does this mean the bottle broken? If I add more, the fluid hits the ground?
If it is broken, how can I access this area? Is fender removal a must?
I cannot get it to fill even to a place where I can look in it and see it.
Any input? Would this be covered under warranty?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stickercuttingcom »</TD></TR><TR><TD CLASS="quote">How far up can you fill the washer fluid in the 06's? I cannot get it to fill all the way up to the cap - does this mean the bottle broken? If I add more, the fluid hits the ground?
did you even get any body work done or ever removed the fender on that side?
i had the same problem on my ap1 because i guess they removed the fender to paint it or some ****. the washer resorvoir is a 2 piece thing... the neck and the base of the reservoir. when they put the fender back they must have separated the two pieces which caused it to leak and not get filled up past a certain level (still worked fine just wouldn't fill up). i ended up fixing it myself but it's an annoying pita. if that is your problem, you have to take the pass side wheel off, undo the fender lining and try to reach in and figure it out. it's not too hard just annoying.
hope this helps
hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI »</TD></TR><TR><TD CLASS="quote">who needs washer fluid? take the whole damn thing out....</TD></TR></TABLE>
My 2004 still has the original washer fluid in it when I picked it up from the show room 4 years ago. I never use that ****.
Water still beads up on my windshield.
Thunder Cat
Dec 9, 2005 03:39 AM
