help installing viper 791xv into 88 crx si
Old Mar 10, 2008 | 11:20 PM
bp's Avatar
bp
Default help installing viper 791xv into 88 crx si
Hello,
I'm installing a viper 791xv into an 88 crx si. This is my first time installing an alarm so be patient with me. I have install plenty of radio and amplifier but never an alarm. First question is on the main harness. White/Blue remote start (-) activation input, from my understanding, is it correct that this wire basically connects to a grounding switch? Second question is on the relay satellite. There are 2 red wire with 30 amp fuses. I wired these up individually to white/black 12v on my ignition harness. What about the red/white wire on the relay satellite? It is also a 12v input but what do I wire it to? any help would be greatly appreciated. thanks
Old Mar 11, 2008 | 05:01 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: help installing viper 791xv into 88 crx si (bp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bp &raquo;</TD></TR><TR><TD CLASS="quote">White/Blue remote start (-) activation input, from my understanding, is it correct that this wire basically connects to a grounding switch?</TD></TR></TABLE>
Correct, momentary ground on this wire acts as if you pressed the remote start button on the remote. We usually de-pin this wire as it's not needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bp &raquo;</TD></TR><TR><TD CLASS="quote">Second question is on the relay satellite. There are 2 red wire with 30 amp fuses. I wired these up individually to white/black 12v on my ignition harness. What about the red/white wire on the relay satellite? It is also a 12v input but what do I wire it to?</TD></TR></TABLE>
Same as the red wires, it should be connected to a good constant 12v source.
Old Mar 11, 2008 | 12:05 PM
bp's Avatar
bp
Default Re: help installing viper 791xv into 88 crx si (White Smoke)
Thank you White Smoke. I'll give it a try tonight.
existanzcivicb20
23
Feb 10, 2014 06:54 AM
Rand The Man
Audio / Security / Video
11
Aug 15, 2012 11:50 PM
nethern
Jul 25, 2011 05:39 AM
o_0
Dec 12, 2010 09:36 AM
philkehn
36
Dec 9, 2007 03:34 PM
