How to check codes from obd2 to obd1
Old Mar 10, 2008 | 10:09 PM
Ruben19's Avatar
Default How to check codes from obd2 to obd1
i have a 2000 si with a built poor mans r and im running a obd1 ecu with jumper hardness.
my engine light came on today after driving for 2 miles.
I tried to jumped the service connector(the same way you do the obd1) but didnt work. the light blinked forever and never stoped.
the original obd2 connector wont read either(used a obd2 scanner).
I cant use my original p2t ecu beacuse the car will run like **** and will throw a code for secondary o2 sensor.
What to do and what you guys do?
Old Mar 10, 2008 | 10:37 PM
garren's Avatar
Default Re: How to check codes from obd2 to obd1 (Ruben19)
hey i cant answer your question but im also having a problem with obd 2 ****. i got a 96 civic ex and i needed a jumper harness for obd 2 to obd 1, the problem is that the harnesses are mainly for manuals and i have an automatic there is a way to re wire it to use it on an automaic, u wouldnt happen to know how or where i can find out would u?
Old Mar 10, 2008 | 10:42 PM
Ruben19's Avatar
go to
http://www.kenji211.com and send him an email
he will answer this question for you
he also sells jumper harness so you know he knows
Old Mar 10, 2008 | 10:43 PM
Ruben19's Avatar
maybe i should ask him too
about my problem
good idea
Old Mar 11, 2008 | 10:16 AM
Ruben19's Avatar
anyone else
EkCoupeTurbo
May 13, 2013 05:16 PM
silentkid
Dec 18, 2008 11:30 AM
FrederickRighteous
Mar 17, 2008 11:27 AM
JONESER
23
Mar 7, 2008 05:09 AM
goowakjai
Mar 22, 2005 10:47 PM
