my car is trippen with ac
Old Mar 10, 2008 | 07:49 PM
allshownogo's Avatar
Default my car is trippen with ac
my problem is when i turn on the a/c my rpms hop so after i tested to see that alternator was pushing power to the battery with a volt meter(which checked out fine)I went to inspect the belt and noticed that it wasnt there. there should be three belts right?(95 dx) so if i get an ac belt put on i wonder would that stop the hopping.
Old Mar 10, 2008 | 08:08 PM
crazyguy's Avatar
Default Re: my car is trippen with ac (allshownogo)
alternator one belt. ps belt and ac belt. so 3 belts. do u have ps ? and idel raises a bit when u turn on the ac. that means your ac system works and it is normal
Old Mar 10, 2008 | 08:15 PM
EKstacy's Avatar
If there is no belt going to your compressor then you should have no a/c. Im pretty sure you should have the power steering belt, alt. belt, and compressor belt. Is the a/c actually cooling?
Old Mar 10, 2008 | 08:19 PM
F&CK i didnt even check. my rpms are 800 with ac not on and then 1200 to 1800 with ac on hopping up and down 12 to 18,12 to 18... i remember that it was the belt in the center. which would that be. i didnt take a long look just glanced.
Old Mar 10, 2008 | 08:33 PM
EKstacy's Avatar
Default Re: (allshownogo)
well, on my crx it was the belt to the right of the engine in the front(as if you are standng in front of the car). It was the farthest one forward. Maybe someone has a picture of the compressor in the bay. Its right under the p/s reservoir.
Old Mar 10, 2008 | 08:51 PM
ANYONE WITH PICS?
Old Mar 10, 2008 | 09:01 PM
EKstacy's Avatar
Ok, i finally found one. I cant circle it with paint cause im on a work computer but the compressor is the one on the left closest to the bottom. In order from left to right.....a/c compressor(bottom left), p/s pump(above and to the right of a/c), alternator(back of engine). Hope this helps
Old Mar 10, 2008 | 09:05 PM
hey awsome pic but im kinda lost. the pully in the back has locations for three belts. im mising the middle one
Old Mar 10, 2008 | 09:15 PM
EKstacy's Avatar
well, by process of elimination.... id say, you have power steering, and your alternator is alternating, so you are missing the belt for the compressor. It is the one in the middle. The first belt(closest to motor) is alt., middle belt is a/c compressor, next belt is p/s.
Old Mar 10, 2008 | 09:21 PM
count me out's Avatar
* B A N N E D *
lol.
Old Mar 10, 2008 | 09:23 PM
so would this be the reason for my rpms to go up and down repeatedly with a/c on? or is it IACV and FITV type thing? also never messed with a belt would. what does it take/how to put one on if you know,if not i really appreciate the help! thanks. I like how ppl like you will go out of there way to help others.
Old Mar 10, 2008 | 09:39 PM
EKstacy's Avatar
Its no problem man. People help me all the time with my car. Just returning the favor
The rpms shouldnt change just because you turned the a/c on if it isnt hooked up. This is probably an IACV or FITV thing.
Also, to put a belt on the compressor, you need to loosen the tensioner above the compressor and slide the belt over the 3 pulleys. then you just pull it tight again with the tensioner. Its easy. Took me about 10 minutes to change one on my CRX.
Old Mar 10, 2008 | 09:43 PM
alright cool. I guess i will double check those valves. thanks again!
Old Mar 10, 2008 | 09:52 PM
EKstacy's Avatar
no problem. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by count me out &raquo;</TD></TR><TR><TD CLASS="quote">lol.</TD></TR></TABLE>
Why u lol? You wasted one of your trial posts to reply with an irrelevant lol?
Old Mar 11, 2008 | 06:58 AM
ShortyzKustomz's Avatar
Well if your missing the belt, The reason the idle is jumping is because the IACV adjusts idle rpm when you turn a/c on etc, So it tries to adjust the idle and theres no load on it, Get a belt and clean the IACV
Old Mar 11, 2008 | 07:27 AM
thats a good point. IACV and FITV have been cleaned and i have tightened up the inside of the FITV.
Old Mar 12, 2008 | 08:14 PM
car is fixed!! I bought the belt last night and put it in on.as soon as the car warmed up I turned the a/c on and the problem was gone. i appreciate everyones help. Thanks!!!
nick105
Honda Civic (2001 - 2005)
Jul 31, 2013 10:18 PM
sinister357
Jul 28, 2007 06:36 PM
sigmiester
Jun 13, 2007 10:10 AM
Cold Fyre
Aug 10, 2006 05:33 PM
DBAl
Jul 20, 2006 09:17 AM
