CEL 8, TDC? replacement? other fix?
each time I hit what I think is the redline (DX cluster has no RPM gauge). it sputters, and throws code 8.
I've done the timing belt, and it's perfectly at TDC, how do I check the TDC connector, if I can't check it, how do I go about this? is replacement of the distributor the only way to go?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98 TDC Sensor (Top Dead Center)
defective circuit or unplugged / defective sensor
I've also rebuild the whole head, new valve seals, had it machined, it's had the works done, all original stuff, and well cleaned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cuteboi »</TD></TR><TR><TD CLASS="quote">each time I hit what I think is the redline (DX cluster has no RPM gauge). it sputters, and throws code 8.
I've done the timing belt, and it's perfectly at TDC, how do I check the TDC connector, if I can't check it, how do I go about this? is replacement of the distributor the only way to go?</TD></TR></TABLE>
You can check it in the FSM at http://media.honda.co.uk/car/o...2.pdf
it's for the DOHC but test procedure is still the same. I'm doing this tonight for the stupid 4-door I have that won't spark lol
Damn, it's an intermittent problem, how do I diagnose this?
the ECU doesn't report it till I attempt to redline, and the PDF file you sent me says that a test drive is needed... Doesn't really help me it seems.
00civex
Jun 1, 2004 04:08 PM
