Trying to isolate clunking sound, please help.
Old Mar 10, 2008 | 03:51 PM
InJ3cted's Avatar
Default Trying to isolate clunking sound, please help.
update: the cross member radius arm bushings did the trick.. the old ones were way worn.
I'm trying to isolate clunking sound, it seems like its on the driverside. Like its hitting the lower firewall.
When I do a shake down of the front end everything is tight.
so far I've replaced
1990 crx si
- rack end bushing and adjusted up my gearbox
- Driverside outer tie rod
- replaced old shocks with GC /koni setup
It only makes this sound when I accelerate from a stop onto an uneven surface. ( like leaving my apt onto the main road dips down then back up) I also feel it in the steering wheel.
Which makes me believe that its somewhere in the steering column to the gearbox. Is there something in there that would make that noise?
I just dont want to waste money on the wrong parts...
thanks
oh and pics because people like pics
http://www.flickr.com/photos/dennytran/2315188913/
Modified by InJ3cted at 3:59 PM 3/15/2008
Modified by InJ3cted at 4:00 PM 3/15/2008
Old Mar 10, 2008 | 04:27 PM
97grnrs's Avatar
Default Re: Trying to isolate clunking sound, please help. (InJ3cted)
rear motor mount bolts or broken rear cross member is what i usually find. or the trailing arm bushings in the front lower crossmember
Old Mar 10, 2008 | 05:12 PM
Smokinsax's Avatar
The Boot
is it clucking just once or does it do it continuously? Maybe check the inner cv joints
Old Mar 10, 2008 | 05:47 PM
InJ3cted's Avatar
Default Re: (Smokinsax)
o<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">rear motor mount bolts or broken rear cross member is what i usually find. or the trailing arm bushings in the front lower crossmember</TD></TR></TABLE>
I'll have to inspect closer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">is it clucking just once or does it do it continuously? Maybe check the inner cv joints
just once usually on acceleration.
Old Mar 10, 2008 | 06:00 PM
crxricer66's Avatar
Default Re: (InJ3cted)
have you checked ball joints??
Old Mar 10, 2008 | 06:31 PM
SIred91's Avatar
Rainman
Default Re: (crxricer66)
I would put money on it being the rear motormount or crossmember...Lemme know if you need a second pair of hands and I'll come help if you need it.
Pm me for phone number
Old Mar 10, 2008 | 07:12 PM
InJ3cted's Avatar
Default Re: (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxricer66 &raquo;</TD></TR><TR><TD CLASS="quote">have you checked ball joints??</TD></TR></TABLE>
yes, I have had play on the driver side but it was from the wheel bearing, and I replaced it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">I would put money on it being the rear motormount or crossmember...Lemme know if you need a second pair of hands and I'll come help if you need it.
Pm me for phone number</TD></TR></TABLE>
cool man.... i'll have to come play some xbox with you and maldito x
btw I have hasport mounts... and the crossmember radius arm bushings are factory so i dont know
Old Mar 10, 2008 | 07:18 PM
biggee's Avatar
to check your ball joints properly on our style suspension you have to jack up on the lower control arm near the ball joint and pull the bottom of the tire in and outwards. make sure you have a jack stand there in case you pull too hard. Have a buddy shake while you look for play.
I want you to check your sway bar body bushings and see if there is any play in those. That will cause a clunk when you hit bumps. You may need a pry bar in there to move the bar around to see if there is play.
I know you said you had Hasport mounts but make sure the bolts are all tight as well.
Old Mar 10, 2008 | 08:55 PM
InJ3cted's Avatar
Default Re: (biggee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggee &raquo;</TD></TR><TR><TD CLASS="quote">to check your ball joints properly on our style suspension you have to jack up on the lower control arm near the ball joint and pull the bottom of the tire in and outwards. make sure you have a jack stand there in case you pull too hard. Have a buddy shake while you look for play.
I know you said you had Hasport mounts but make sure the bolts are all tight as well.</TD></TR></TABLE>
i'll try that tomorrow thanks
Old Mar 10, 2008 | 11:53 PM
phoenix1.8's Avatar
my car did something similar, and it ended up being the steering rack. bolts were just loose, but not anymore!
Old Mar 11, 2008 | 06:03 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
strut rod bushings when they were to a certain point have been responsible for a clunk. and even new at the dealer they are still pretty easy on the pocket.
Old Mar 11, 2008 | 04:33 PM
InJ3cted's Avatar
Default Re: (ComeOnKip)
Alright I got it up on the alignment rack today and we noticed that there was play in the radius/strut rod in the crossmember due to the bushings being worn, while we were shaking down the front end.
I ordered some ES bushings, oem would have been more and would have taken longer to get .
I'll keep it updated
Old Mar 11, 2008 | 05:10 PM
grog's Avatar
I'm not trying to talk you out of ES bushings, but do a search on them.
I was going to put some on my car, but found out they require maintanance, and if not maintained wear out very quicky compared to rubber.
ES advertising is very very deceptive!
Old Mar 11, 2008 | 05:49 PM
biggee's Avatar
my ES bushing kit is the graphite impregnated ones...no maintenance required and no squeaks either!
Old Mar 11, 2008 | 05:56 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggee &raquo;</TD></TR><TR><TD CLASS="quote">my ES bushing kit is the graphite impregnated ones...no maintenance required and no squeaks either!</TD></TR></TABLE>
Same here......love em'.
Just make sure you get the black ones.
Old Mar 12, 2008 | 05:12 AM
ComeOnKip's Avatar
I think since my car still sees more daily driving then track duty, i'll be getting those Mugen hard rubber bushings from King Motorsports soon. They are high dollar but fwiw I'd like to see a comprehensive review on them.
Old Mar 12, 2008 | 06:43 AM
grog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip &raquo;</TD></TR><TR><TD CLASS="quote">I think since my car still sees more daily driving then track duty, i'll be getting those Mugen hard rubber bushings from King Motorsports soon. They are high dollar but fwiw I'd like to see a comprehensive review on them.</TD></TR></TABLE>
good luck differentiating between them! they seem identicle to stock bushings, but by all means.
I believe one thing that has never been confirmed is whether or not these are infact harder than stock.
Old Mar 12, 2008 | 07:02 AM
ComeOnKip's Avatar
Well I'm sure they are... and juding them visually is no help as they are rubber... just like the stock bushings, just made do a higher stiffness. I have a durometer at my dipsosal so i'll give you exact hardness numbers when I recieve mine.
Old Mar 12, 2008 | 08:24 AM
InJ3cted's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip &raquo;</TD></TR><TR><TD CLASS="quote">Well I'm sure they are... and juding them visually is no help as they are rubber... just like the stock bushings, just made do a higher stiffness. I have a durometer at my dipsosal so i'll give you exact hardness numbers when I recieve mine. </TD></TR></TABLE>
Nice, keep us updated I'm interested as well. I heard for their RTA bushings they are just repackaged OEM. My RTA is next.
Just make sure you get the black ones.</TD></TR></TABLE>
they didnt have black ones oh well I'm overly concerned
Also receiving my shift linkage fix from hasport today woot
Old Mar 15, 2008 | 01:59 PM
InJ3cted's Avatar
[b]update[b]: the cross member radius arm bushings did the trick.. the old ones were way worn.
geoken
May 12, 2014 05:14 AM
shlammed
Suspension & Brakes
Feb 17, 2010 12:03 PM
higgunscrx
Jan 18, 2007 06:10 PM
an2ny888
Apr 14, 2004 08:54 AM
Agent Daimon
Jan 13, 2003 02:48 PM
