gsr in ls.
Old Jul 7, 2002 | 09:00 PM
fourdoorteg's Avatar
Default gsr in ls.
i have an 94 ls integra. and i bought a 95 gsr long block with no intake manifold and i was wondering if the type r manifold will bolt up to the gsr head. i thought it did until i saw 2 people post that it could but it has to be modified. is this true??
also, can i use my ls header and cat or do/can i use gsr header with ls cat??
thanks
Old Jul 7, 2002 | 09:02 PM
bboychris's Avatar
Default Re: gsr in ls. (fourdoorteg)
the manifold should work just fine
Old Jul 7, 2002 | 09:05 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: gsr in ls. (vteckid)
the type R manifold will NOT fit on a GSR head.
(type R) single runner dual runner (GSR)
Old Jul 7, 2002 | 09:06 PM
oh, if you want an ITR manifold on your GSR head, you'll have to buy a skunk2 one - it's the same design but it fits.
Old Jul 7, 2002 | 09:12 PM
yea, i found that out. imma go with the skunk2. what is the difference between single and dual plain and how does it work?
but does anyone know about my other question
"also, can i use my ls header and cat or do/can i use gsr header with ls cat?? "
Old Jul 7, 2002 | 09:22 PM
Tanner's Avatar
New User
LS header will not fit.. I have a GSR header if you want one.. let me know
Old Jul 7, 2002 | 09:38 PM
Naya the Dingo's Avatar
gsr has another set of butterflies that open at 5800rpm
Old Jul 8, 2002 | 08:33 AM
zilverz's Avatar
Default Re: gsr in ls. (dLo GSR)
hmm the ITR intake manifold can be modified to fit the LS ... i thought
for sure it fit the GSR ... on me ):
Old Jul 8, 2002 | 10:54 AM
JDMCRVTEC's Avatar
no the type r manifold will not fit, you have to get the skunk 2 manifold.
Old Jul 9, 2002 | 01:13 PM
eccentric.ek's Avatar
skunk
Old Jul 9, 2002 | 02:34 PM
xero-cool's Avatar
Single short runners like the type R will give more top end power.
Longer runners like the LS manifold gives more low end power because of proper swirling mixing of the air/fuel mixture at lower rpms.
The GSR dual runners will give the best of both worlds and have a very nice midrange. That's why the GSRs have such a flat torque curve. However, because it is essentially still a dual "long" runner even when the butterflies open for the air to shortcut into the short runner directly to the head, the GSR manifold runners have too much surface area = extra friction = less air flowing to head at high rpms = not so great top end like the type R but more midrange and low end.
Hope that helped
[Modified by xero-cool, 11:34 PM 7/9/2002]
Old Jul 9, 2002 | 02:51 PM
Malice's Avatar
New User
yes it will. My car is an 4 door LS with a GSR motor. for a while i was using my LS header and cat.didnt have to modify the b-pipe at all. now i have a 5zigen header for a Type R and test pipe. still didnt have to modify my b pipe at all. any questions just ask away.
[Modified by MaliceGSR, 3:51 PM 7/9/2002]
Old Jul 9, 2002 | 05:30 PM
Cramerox's Avatar
Actually the ITR will not be a direct fit but you can modify it so that it will fit the gsr head. For the money u might as well get the skunk2 mani.
Old Jul 11, 2002 | 04:36 PM
wizzards581's Avatar
Default Re: gsr in ls. (Cramerox)
itr intake manifold dont fit on the gsr head?? humm... i thot i does.. how come one of my frien had a b16 head with itr manifold? fits rite in.. and he uses b18 block...
Old Jul 11, 2002 | 04:50 PM
LOwrestling2001's Avatar
Default Re: gsr in ls. (wizzards581)
b16 and ITR head are the same...except the ITR one flows better
xlilninjax
Oct 28, 2010 01:09 PM
hamburgler
Jan 13, 2006 08:41 AM
X2BOARD
Dec 31, 2004 07:49 AM
Droppedatbirth!
Aug 20, 2004 09:20 PM
DsBananas94LS
Aug 8, 2004 05:48 PM
