what is this battery terminal fuse holder??
Old Mar 10, 2008 | 12:37 PM
kalm_traveler's Avatar
Default what is this battery terminal fuse holder??
Here's the quick story of the car in general, then a pic of my question.
91 DX 4-door. Kid told me his uncle was fixing it for him but was takin too long so he wanted to get rid of it.
Distributor was wedged in at an angle 180-degrees backwards. I switched it around. Has visibly new distributor, cap, and rotor.
Timing belt is fine, mechanical timing is correct.
For some reason there is no spark at all, even though the wire harness has power on it.
Anyways, on the + battery cable there is a 2-fuse holder attached that connects into the main engine harness just below the battery. The 88 4-door and 90 hatch I have fixed didn't have this so anybody know what it is?
here's a pic:
Also, fuel pump works - I drained the tank and put new gas in which you can smell out the tailpipe after cranking the motor.
If you have anything I can inspect as far as the no-spark problem or if you know what this fuse holder is for plz help
Old Mar 10, 2008 | 12:43 PM
Pooper's Avatar
Default Re: what is this battery terminal fuse holder?? (kalm_traveler)
looks after market to me. Probably stereo and car alarm add on nonsense. where do the wires run to?
Old Mar 10, 2008 | 12:45 PM
cuteboi's Avatar
I read people saying to check the main relay near the fuse block, check your connections at the distributor, and check fuses in the fuse block.
and that extra set of fuses at the battery can't you follow the cable? it seems like they extend behind the battery, maybe it's for foglights? just a random thing I could think of for such an OEM look to that connector.
EDIT:
@Pooper, to me it looks like the connector on a Honda fit.
Old Mar 10, 2008 | 12:52 PM
Default Re: what is this battery terminal fuse holder?? (Pooper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pooper &raquo;</TD></TR><TR><TD CLASS="quote">looks after market to me. Probably stereo and car alarm add on nonsense. where do the wires run to?
It runs down behind the battery into the OEM harness. Like between the battery and the air filter box.
cuteboi ty - I'll pull the main relay and try resoldering all the joints. Cross your fingers for me plz
*EDIT*
here is a pic of where the 2 wires enter the rest of the harness:
Fuse holder has 2 30-amp fuses in it.
Old Mar 10, 2008 | 01:20 PM
DailyDriverCivic's Avatar
My car has that same battery terminal fuse holder, so it is stock. (90 EX)
Old Mar 10, 2008 | 01:28 PM
SIred91's Avatar
Rainman
Default Re: what is this battery terminal fuse holder?? (DailyDriverCivic)
It might be a fuse for the AC .....
Any luck today on that thing?
Old Mar 10, 2008 | 01:51 PM
Pooper's Avatar
Default Re: what is this battery terminal fuse holder?? (SIred91)
thats strange my rex never had one.
Old Mar 10, 2008 | 02:12 PM
cuteboi's Avatar
your rex doesn't have AC, right?
b18apwr's Avatar
Those are the power seat belt fuses IIRC.
Old Mar 10, 2008 | 02:23 PM
SIred91's Avatar
Rainman
Default Re: what is this battery terminal fuse holder?? (b18apwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18apwr &raquo;</TD></TR><TR><TD CLASS="quote">Those are the power seat belt fuses IIRC.</TD></TR></TABLE>
hnmm, that could probably be correct...
Old Mar 10, 2008 | 02:39 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
hnmm, that could probably be correct...</TD></TR></TABLE> 100% correct on being the fuses for the passive seat belts.
Old Mar 10, 2008 | 02:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">It might be a fuse for the AC .....
Any luck today on that thing?</TD></TR></TABLE>
They got it - power seat belt thingies.
No luck getting it started. I had vAutozone test the two coils and both igniters.
Coils were both mid-spec, the igniter I thought was bad indeed was, other one is just peachy. The guy suggested that possibly the coil pickup sensor was bad but neither he or I know how to test it.
I'm gonna resolder all the joints on the main relay now.
Thanks again guys for clarifying the seat belt fuse thingy.
mr.mengo
Jun 2, 2012 10:31 PM
Greyout
Jun 27, 2011 04:18 PM
Dysturbed_4dr
Mar 8, 2004 07:13 AM
rasta420
Nov 6, 2002 08:41 PM
