something happen to my R
it rumble alot and the cams sound like toda spec c. I have to that the sound was nice
You definitely have bent valves and the clutch could be fried as well...
LMAO...that is only a nice sound when you actually have Spec C's in the car...
I had to read the original post, five times to find the part about Spec C's.
Paragraphs make things easier to read.
This won't be covered under warranty.
Driver error is not the dealership's fault.
Phony warranty claims make it harder for the rest of us with squeaking driver's seats, loose dipstick t00bs, and temperamental synchros to get our legitimate problems fixed...
Damn this board whent form getting cars stolen to bent valves all of a sudden. Damn I hope I never do this
I've done this a few times. I am guessing you have some bent valves, and the rivetes that hold the pressure plate together broke, that why you cant get into gear. If it is a stock pressure plate, I will bet money on it. I have broken three. Ryan
my car is a 2001 with 10000miles
and by the way my problem is fixed, my cuz is a mechanic and he took a fast look at it and told me its the valve adjustement
he adjusted the valve and the problem was gone, now I have to shop for a new clutch, be cause mine was tosted
yeah you could be driving down the freeway and one of those bent valves might decide to drop in your cylinder and do the twist with one of your pistons. But I will tell you I missed shifted my ls/vtec from third to second and it went to at least 10k but only broke the clutch so you might have gotten lucky. But I don't think so
thanks guys for the support, ill make shure that the valve are ok.... I already checked and there was no leak after the incident.
Im changing my valve train for toda along with the c or b camshaft later this summer. This will be a good moment to buy new ferrea valve and do some headwork.
what kind of clutch is good for a toda c or b setup....I was thinking, clutchmaster stage 3 with aluminum flywheel
