94-01 JDM integra center console question
I have purchased a real JDM type R cup holder, ashtray,shift boot cover, as well as a radio block of plate and none of this will fit my USDM console. Is all that i need is the real jdm version or do i need somthing else. I really appreciate your alls help this has been driving me crazy and i am sure u all will know more than me on this. Thanks again.
The USDM console curves to the right on the passenger side USDM passenger side. The JDM console curves to the left on the USDM driver's side. The shift plate will only fit on a JDM console at the curve is not correct.
Thank you very much. another thing is, is the ashtray the same way cause it does not seem to wanna fit the USDM either.
Got my JDM center console in today and everything bolts to it excellent like you said but it will not bolt correctly to my upper dash. How do i find the upper dash in order to make this work perfect?
jdm shift bezel cig lighter and ashtray will not fit in usdm center console and if you want to fit your jdm center console im pretty sure you need a rhd dash. you need tha usdm verisons of these pieces to fit your usdm console. tha cupholders are interchangeable though.
I contacted password JDM and they said that it can fit with some modifications. I am not sure how to make the modifications or actually what modifications need to be done because it seems to me to be way off. If anyone knows what the modifications are can you please let me know. Thank all who have responded to my post you all have been a great help so for this little situation.
bartek_b
Aug 3, 2003 10:03 AM
