coolant hose
Old Mar 10, 2008 | 08:49 AM
zdizzle's Avatar
Default coolant hose
What is the name/part# of this hose after doing some matience i noticed a small coolant leak, i want to replace it asap. I searched wth no luck thanx
[IMG][/IMG]http://img.photobucket.com/albums/v488/zdizzle/PICT3160.jpg
[IMG][/IMG]http://img.photobucket.com/albums/v488/zdizzle/PICT3159.jpg
Old Mar 10, 2008 | 08:51 AM
zdizzle's Avatar
Default Re: coolant hose (zdizzle)
zdizzle's Avatar
srry about noob post and crappy pics
Old Mar 10, 2008 | 08:54 AM
Phre0nBurn's Avatar
Its hard to tell from the pic, but it looks like a heater hose... Either way, just disconnect it, and take it into Pep Boys or Autozone and just have them cut you some new hose of the same length... Very easy to fix...
Oh, and when you pull it off you will lose a lot of your coolant, so maybe get a gallong of that as well.
Old Mar 10, 2008 | 08:56 AM
zdizzle's Avatar
thanx it my dd and i depend on it, i dont lke coolant leaks
Old Mar 10, 2008 | 09:03 AM
Phre0nBurn's Avatar
I know how it is.
I just replaced that same hose (if its the one I think it is) 2 weeks ago... Did it in the parking lot of Pep Boys... Just let the motor cool for 20-30 mins before doing it, and be prepared to make a mess on the ground. It isn't hard though. You might need to really work at getting that hose off, as rubber hoses mate to surfaces after a few years, and can be a total PITA to remove... A flathead screwdriver would help to pry the hose off of the nipple after the clamp is removed...
Old Mar 10, 2008 | 09:19 AM
zdizzle's Avatar
Default Re: (Phre0nBurn)
for the help, ht rules im already doin a bunch of matience today so i might be able to get to it better
Old Mar 10, 2008 | 09:21 AM
zdizzle's Avatar
Default Re: (zdizzle)
black magic or armorall is good when trying 2 remove stubborn hoses
Old Mar 10, 2008 | 09:51 AM
crxd16's Avatar
Can you not get away with chopping the hose by about an inch to get rid of the damaged area
then shove the hose back on.
There might be enough "slack" in it so that its still long enough to chop and re-use.
Old Mar 10, 2008 | 10:50 AM
zdizzle's Avatar
Default Re: (crxd16)
once u remove a rubber hose buy a new one if funds are avalible, they expand and contract wth all the heat and pressure on them but good idea thanx
creepy116
Aug 5, 2007 08:51 PM
Paprika
Dec 21, 2004 04:51 AM
