obd2 distributor w/ obd2b wiring harness *HELP* tach output sensor questions
Old Mar 10, 2008 | 07:53 AM
xlasianizelx's Avatar
Default obd2 distributor w/ obd2b wiring harness *HELP* tach output sensor questions
i have a 99 civic ex sohc vtec and im swapping in a b16a4 motor... the shop said it was a direct drop in but it wasnt. really.. the wiring was different,
ive been given help from other users b4 about using my stock ex harness for the b-series distributor.. i have a couple questions...
where am i suppose to connect the extra blue wire from the distributor (tach output) to?.
the motor doesnt have a crankshaft position sensor so is that safe to run? (im running a si p2t obd2b ecu)
people said i can run the blue wire to another wire thats around the driver side shock tower.. can any1 post some pics on where that is?...
also there are 3 extra plugs left empty on my harness...
there isnt a 2nd plug for my vtec on my b16 motor
there isnt a plug on my fuel rail on my b16 motor
there isnt a crankshaft sensor on my b16 motor
if you can help... please do.. thanks
Old Mar 11, 2008 | 07:18 AM
bump ne help here?
majerst
Jan 22, 2010 10:23 AM
talonturbotsi94
Aug 18, 2007 05:23 PM
greddy2smoke
Jul 16, 2007 04:27 PM
WuRKD b16
May 20, 2004 11:15 AM
