another idle fluctuating problem, 1996 civic ex
Old Mar 10, 2008 | 02:34 AM
v8killaz's Avatar
Default another idle fluctuating problem, 1996 civic ex
I start my car its fine goes to idle(600rpm) but then as I giv it sum gas and let go it fluctuates from 1500to1000to1300then to idle slowly again this is not a major problem but when I drive it is on the highway I drive for 10 min in 5th and push the clutch the rpm doesn't idle to 600rpm it stays at like 2500rpm and fluctuates but doesnt completly idle which will eat up my gas any help
Old Mar 10, 2008 | 05:20 AM
slo_hatch's Avatar
Default Re: another idle fluctuating problem, 1996 civic ex (v8killaz)
have you ever changed any of the sensors? like the tps, map, o2 sensor...any of those things?
Old Mar 10, 2008 | 05:25 AM
Former User's Avatar
Default Re: another idle fluctuating problem, 1996 civic ex (slo_hatch)
Possible causes:
-dirty IACV (clean with carburetor cleaner)
-air in the cooling system (bleed)
-check for intake air or vacuum leaks (spray carburetor cleaner around hoses & IM & TB gaskets and look for idle change)
Old Mar 10, 2008 | 08:22 AM
IIXtremeHansen's Avatar
Throttle plate stuck from build up? Check it out.
Old Mar 10, 2008 | 09:51 AM
boostedjdmdc2's Avatar
You should try cleaning out your IACV or replacing yours with one that you know works. I had a problem that sounded kinda like this.
Old Mar 10, 2008 | 10:48 AM
v8killaz's Avatar
Default Re: (boostedjdmdc2)
thx for the replies,
iac sensor I'll clean soon
throttle plate was cleaned perfect
and I'll have to bleed and chk for air leaks
EM2 Ficial
Honda Civic (2001 - 2005)
Mar 29, 2013 04:33 PM
1991civicb16
Jul 16, 2011 12:38 AM
4tika4
Apr 19, 2009 09:43 AM
hatchofdoom
Mar 27, 2008 11:13 PM
Kamin
Jan 12, 2002 08:43 AM
